Author Topic: TurnedUp  (Read 106429 times)
TurnedUp
« Reply #225 on: June 17, 2013, 12:19:01 PM »
KDP
Re: TurnedUp
« Reply #226 on: June 24, 2013, 11:55:12 AM »
Hard to be accurate because of dumped in buckets and weird high flow diesel pumps at the rest stop by Rausch that click off instantly, but my educated guess puts me a little over 13mpg.
Granted I started with 3/4 of a tank before topping it off Thursday night, but I spent $48 on fuel this weekend. That is FAWKING awesome.
50/50 on the way down, 60% on the way back. Not too bad on flat, but it has a noticable white haze pulling hills. I was hoping someone would be behind me for a while on the way back to put my mind at ease that it wasn't too noticeable or smelly. Still hoping timing helps.
When I cleaned the intercooler boots, both the of the larger t-bolt clamps on the intercooler broke so I temporarily replaced with a regular hose clamp. That sucked, must have pulled over to pop that back on at least 5 times. As Alex would say, things that really need fixing remind you they need fixing quite often. New clamps ordered.
Re: TurnedUp
« Reply #227 on: June 24, 2013, 12:06:05 PM »
They look like you are driving a 1988 astro van with a serious oil burning issue when you are at 100% motor oil but who the hell cares. My truck throws out a serious smoke screen at idle
Re: TurnedUp
« Reply #228 on: June 24, 2013, 12:27:45 PM »
i think im going to start 12 shoppinig for a shovel replacement haha
TurnedUp
« Reply #229 on: June 24, 2013, 01:16:45 PM »
Holmes 440 on a rusty second gen would be sweet!!
Re: TurnedUp
« Reply #230 on: June 24, 2013, 01:21:54 PM »
i think the PTO might need to be upgraded to an ENGO though haha
awl4928
Re: TurnedUp
« Reply #231 on: June 24, 2013, 01:38:59 PM »
What could go wrong.  The engo it totally safe for lifting stuff as long as your nowhere in the drop range.
Re: TurnedUp
« Reply #232 on: June 24, 2013, 01:58:43 PM »
dodge 205 swap. "easy"
Re: TurnedUp
« Reply #233 on: June 29, 2013, 06:03:15 PM »
Dump Bus lives on!!
Re: TurnedUp
« Reply #234 on: June 29, 2013, 06:04:13 PM »
Ignore that whole bumper thing going on there haha
Re: TurnedUp
« Reply #235 on: June 29, 2013, 06:37:16 PM »
Yeah!!
Back into a pole and straighten out that bumper now.
Re: TurnedUp
« Reply #236 on: June 29, 2013, 08:27:07 PM »
Yeah, like the same pole at work I hooked it ok to bend it in the first place
Re: TurnedUp
« Reply #237 on: July 07, 2013, 10:15:21 PM »
Found some concerning rust on the hitch during bed removal. Stick with class V? Or something cheaper and closer rated to my trailer... Or will I regret that? Might not even be cheaper. Will price from Arie.
Re: TurnedUp
« Reply #238 on: July 07, 2013, 10:21:18 PM »
I'd go to a 2" class V so you're not so limited on drawbars - but you already have this one. If you're not planning on towing piles of trailer and wanting to borrow drawbars then it doesn't much matter.
Re: TurnedUp
« Reply #239 on: July 09, 2013, 10:18:35 AM »
Update: this thing leaks oil. More than it used to.
