Author Topic: TurnedUp  (Read 106428 times)
Re: TurnedUp
« Reply #240 on: July 09, 2013, 10:22:06 AM »
Reporting loss of pressure is way more important than leaking a bit!
Re: TurnedUp
« Reply #241 on: July 09, 2013, 10:32:57 AM »
I was going to wait until the new sensor said the same thing.
Re: TurnedUp
« Reply #242 on: July 09, 2013, 10:40:58 AM »
Research I did says these sending units are notorious for sucking. Mechanical gauge costs as much as the sender and threads right in. Might do that.
Re: TurnedUp
« Reply #243 on: July 09, 2013, 10:46:34 AM »
good pre-panic plan
Re: TurnedUp
« Reply #244 on: July 09, 2013, 10:47:31 AM »
I wonder if I have a known good one hanging out the side of my block. If I didn't damage it on the way out of the truck I probably do.
Re: TurnedUp
« Reply #245 on: July 09, 2013, 10:54:05 AM »
Sweet. Throw it on my tab?  8)
Re: TurnedUp
« Reply #246 on: July 09, 2013, 10:59:27 AM »
Only problem I have with mechanical is that stock guage was reading 40+ 90% of the time, then would get weird after 2hrs of driving. Not sure how to replicate that other than when I head to Rausch in 3 weeks.
Re: TurnedUp
« Reply #247 on: July 09, 2013, 03:14:33 PM »
Thought: what regulates oil pressure in the engine?
Is it possible the oil filter has some bypass in it?
Re: TurnedUp
« Reply #248 on: July 09, 2013, 04:13:25 PM »
All oil filters have a bypass. Otherwise if they clog, you would have no oil pressure at all – and dirty oil is worlds better than no oil.
However, the filter bypass is not what regulates oil pressure. I'm going to have to stop talking here because I am uncertain of whether there actually is any true pressure regulation, or if it's just the tolerances in the engine that determine pressure.
Re: TurnedUp
« Reply #249 on: July 09, 2013, 04:16:02 PM »
my understanding is the bipass is not in the filter, its in the block
you can get shit stuck in this spring and plate.  i had a piece of a wire wheel stuck in a chevy motor bipass once when i went to install a spendy oil pump, i found that is the issue, not the pump.
Re: TurnedUp
« Reply #250 on: July 09, 2013, 04:22:06 PM »
I should have remembered that wire wheel wire
Re: TurnedUp
« Reply #251 on: July 09, 2013, 04:22:15 PM »
I have confirmed via diagrams there is an oil pressure relief in the filter housing. Plan to inspect that tonight.
Re: TurnedUp
« Reply #252 on: July 09, 2013, 04:23:40 PM »
The intermittency (word?) is what concerns me. May seem fine for the next three weeks then 2hrs into my trip to Rausch the pressure drops.
Re: TurnedUp
« Reply #253 on: July 09, 2013, 04:25:22 PM »
look at you and your diagrams
Re: TurnedUp
« Reply #254 on: July 09, 2013, 04:26:34 PM »
temperature? towing?
drops to what?
