Author Topic: TurnedUp  (Read 106407 times)
TurnedUp
« Reply #105 on: April 29, 2013, 08:44:40 PM »
#1 injector. Switching it w #2 to see if the problem follows.
TurnedUp
« Reply #106 on: April 29, 2013, 08:45:36 PM »
#2 injector
TurnedUp
« Reply #107 on: April 29, 2013, 10:49:27 PM »
Injectors #1 and #2 swapped and worse. #1 was the original problem cylinder that made no difference in cracking open before I started today. Now, cracking either one makes no difference and it definitely runs worse than before.
When #1 is cracked, fuel dribbles out. When #2 is cracked, fuel comes spraying out pulsating.
My logic tells me that a fuel delivery issue somewhere on the #1 delivery system damaged the #1 injector (from running too hot or something?)
TurnedUp
« Reply #108 on: April 30, 2013, 09:14:29 AM »
Sounds like the cleaning of #1 didn't fix that, and something with #1 on the pump side as well. I'd pull delivery valves and swap em. Look for broken or stuck parts - esp as in that thread you posted yesterday.
Re: TurnedUp
« Reply #109 on: April 30, 2013, 10:15:52 AM »
Will try cracking the line at the pump. If nothing there either, I will pull the DV's.
I can swap them back and forth? Read some thing about not swapping them as they were toleranced with the pump? Seems weird, forgive my ignorance.
Re: TurnedUp
« Reply #110 on: April 30, 2013, 10:27:08 AM »
I know it's a common upgrade to swap DVs for larger ones, so it can't be that critical? Chad's a believer in full cut valves, and I can see that. I really don't understand the point of them. I would like to know more, but haven't researched them.
Re: TurnedUp
« Reply #111 on: April 30, 2013, 12:49:02 PM »
http://www.bostechfuel.com/injectors.php?id=DE891
http://www.fuelinjectorwhse.com/injectors.php?id=DE891
$300 shipped after core charge.
One other things: am I damaging anything by running it with the bad throwout bearing? I read something about scoring the transmission shaft or something? I'd like to get it running right before I tackle that.
Re: TurnedUp
« Reply #112 on: April 30, 2013, 01:13:24 PM »
throwout doesn't spin unless the clutch is in.
you could score the shaft with a bad pilot bushing/bearing
Re: TurnedUp
« Reply #113 on: April 30, 2013, 01:35:38 PM »
Well, it still squeaks a tiny bit even when the clutch isn't in.
I need to research basic clutch assembly drawings so I can understand this I guess haha
Re: TurnedUp
« Reply #114 on: April 30, 2013, 01:39:44 PM »
thrust bearing the slides on trans input
when you push in, the bearing pushes agains the fingers on the clutch to release the spring force on the plate(s)
TurnedUp
« Reply #115 on: May 02, 2013, 09:41:49 PM »
Gambled and spent $60 on the 50k mile injectors. Runs 95% better. Delivery valve on #1 is leaking a decent stream of fuel so I'm guessing that cylinder is just a little down in pressure. Pulled it off and the o ring is chewed up.
Test drive was night and day better than Sunday.
Drinking a beer now.
Re: TurnedUp
« Reply #116 on: May 03, 2013, 10:52:20 AM »
nice\
Re: TurnedUp
« Reply #117 on: May 03, 2013, 11:08:13 AM »
Those o-rings suck, almost never go through a removal. about $1.50 from Cummins IIRC. I'm thinking I should have a spare or two but I haven't seen them in months, no clue where they are.
Great news on the injectors. great great.
Re: TurnedUp
« Reply #118 on: May 03, 2013, 11:16:54 AM »
Very relieved!!! Wish we could have found someone down south selling some $60 injectors and spent 2hrs putting them in instead of countless hours diagnosing weird things and smogging everyone at the campfire out
Also, I can now stand next to the tailpipe without my eyes burning. Pretty sweet!!!!!!  8)
Re: TurnedUp
« Reply #119 on: May 03, 2013, 12:01:49 PM »
Hell, that's a double-win!
