TurnedUp
Pages:
5
6
7
8
39
Topic: TurnedUp (Read 105923 times)
TurnedUp
Reply #75 on:
April 08, 2013, 08:34:11 AM »
Or maybe just needs a fresh bushing to replace oil soaked rubber sloppiness. But that's way way too much.
Fitty bucks?
Re: TurnedUp
Reply #76 on:
April 08, 2013, 08:37:13 AM »
i read track bar was new, assumed bolt or hole egged
Re: TurnedUp
Reply #77 on:
April 08, 2013, 08:39:18 AM »
Trackbar IS new. Bolt isn't moving in hole, bushing is squishing
Re: TurnedUp
Reply #78 on:
April 08, 2013, 08:42:54 AM »
Also need to source a
2-1/2"
ball mount for this guy
TurnedUp
Reply #79 on:
April 08, 2013, 08:58:41 AM »
2 1/2" drop you mean?
Ball sizes are 1-7/8, 2, 2-5/16.
TurnedUp
Reply #80 on:
April 08, 2013, 08:59:58 AM »
Oh, I bet you mean class V hitch/ draw bar. gotcha
Free Loader
Re: TurnedUp
Reply #81 on:
April 08, 2013, 09:00:47 AM »
I assume he is meaning 2 1/2" big boy class 5 receiver size.
Re: TurnedUp
Reply #82 on:
April 08, 2013, 09:06:14 AM »
Yes, 2-1/2" reciever. Took a little searching but Napa has 3" and 5" drop in stock for $45. Etrailer was showing like $70 so that was a relief
Re: TurnedUp
Reply #83 on:
April 11, 2013, 09:42:52 AM »
$77 at Napa and hitch mount, ball, hitch pin procured.
7 prong plug is about to fall off, wires in BAD shape. Also, brake controller does not show any signs of life. Hoping it's the little circuit breaker thingy screwed to the fender.
Re: TurnedUp
Reply #84 on:
April 12, 2013, 09:32:42 AM »
New plug and all is well. Ready!!!!!!!
Re: TurnedUp
Reply #85 on:
April 14, 2013, 10:56:48 PM »
Did about 3hrs round trip towing my Jeep today. Pretty sweet to set cruise at 70 and just... cruise. I let it eat on a couple mild interstate grades, boost spiked to 30 a couple times, EGT never got over 900*F. I think it could use an injector service, my friend here suspected that could be causing the slight roughness at idle. Not too noticeable other than hearing it through the exhaust.
Question: what towing practices will help prolong 5th gear life? I was making a point of not going from 4th to 5th until about 45mph.
TurnedUp
Reply #86 on:
April 15, 2013, 12:10:51 AM »
Stay over 1,800 at absolute min in 5th. Pref over 2k
Last Edit: April 15, 2013, 08:05:18 AM by mr.mindless
Re: TurnedUp
Reply #87 on:
April 15, 2013, 08:49:25 AM »
do not grenade shift to 5th haha
Re: TurnedUp
Reply #88 on:
April 27, 2013, 08:18:34 PM »
Pow pa pow pow
TurnedUp
Reply #89 on:
April 28, 2013, 07:43:54 PM »
It stopped backfiring actually. Did not lose the "running on 5" feeling though. Fuel pressure stayed constant the entire trip, around 55psi.
Lose batter connection made it not want to start again after unloading jeep in my driveway.
Fuel pressure shrader valve did not seal when I took the gauge off after it was started, sprayed fuel everywhere.
Pressing in the clutch pedal gives this awesome squealing noise now.
Not really in the mood to even look at this thing right now
Pages:
5
6
7
8
39
TurnedUp
