Author Topic: High Miler  (Read 302580 times)
Re: High Miler
« Reply #765 on: August 08, 2023, 04:51:33 PM »
Charge pipe popped off the intake horn bringing Sarah’s Jetta back from inspection
Under boost accelerating in 4th appreciating the power of a _modern_ dumpbus I thought I grenaded a driveline lol
Took me a second to evaluate road speed and R’s were still correlated, I just lost 80% power.
Re: High Miler
« Reply #766 on: November 15, 2023, 09:01:09 PM »
RF brake caliper dragging. New to have a front doing something stupid, it’s always a rear. Not enough to pull, but enough to be warm after noticing a brake pedal difference.
Always something
Re: High Miler
« Reply #767 on: November 30, 2023, 07:25:31 PM »
The always-perfect oil pressure on this 462,000 mile animal dropped to the bottom of the gauge as I arrived home just now. Over the course of the last 2 miles of the drive, noticed around 20, then 10, then less as I parked.
No funny noises.
Gauge slightly reactive to RPM, so not a -dead- sender or gauge
Typical is 45 hot idle and higher at cruise
Oil consumption has always been negligible. Maybe a quart low at a 7500-10000 mile, 3 gallon change.
I see I’m at 7750mi, will check and probably change.
Very concerning.
Re: High Miler
« Reply #768 on: November 30, 2023, 07:26:50 PM »
Restarted after writing that, showing 40psi hot idle
Maybe it’s another cluster fuck up like the fuel gauge a couple weeks ago
Re: High Miler
« Reply #769 on: December 01, 2023, 08:12:20 AM »
fingers crossed for ya!
Re: High Miler
« Reply #770 on: December 01, 2023, 11:07:49 AM »
did a little reading this morning - found that the pressure gauge is a complete lie run by the ECM based off of a 6psi pressure switch.
there's a pressure port on top of the oil filter housing, I'll shop for a pressure transducer to add there to the CTS gauges to get a real number since concerns were brought up....
I drove the XJ today.
Re: High Miler
« Reply #771 on: December 01, 2023, 02:23:59 PM »
they salted this week!  put the xj away till spring!
Re: High Miler
« Reply #772 on: December 01, 2023, 03:11:43 PM »
called it fine due to rain. everything else down and broken
Re: High Miler
« Reply #773 on: December 03, 2023, 02:08:22 PM »
68psi cold idle
Re: High Miler
« Reply #774 on: December 03, 2023, 07:06:52 PM »
that sounds better than looking for a new 6.7
maybe weird electrical thing?
Re: High Miler
« Reply #775 on: December 03, 2023, 07:31:39 PM »
15-18 hot idle. 50-60 hot cruise at 2,000 rmp
I think it was a dash snafu. Will be interesting to see how much difference fresh oil and filter makes. Clean fuel filters is the difference between 7-10 and 2-3 psi…
Re: High Miler
« Reply #776 on: December 03, 2023, 07:34:42 PM »
hmm  15-18 hot idle sounds kinda low but not sure what it normally had been running
Re: High Miler
« Reply #777 on: December 03, 2023, 07:37:50 PM »
thats crazy its a fake number though lol
i feel lied to!
Re: High Miler
« Reply #778 on: December 03, 2023, 08:24:46 PM »
Yeah ZERO clue what it was 100.000 miles ago and if that’s same or worse.
Factory low pressure warning is 6psi so I figure over 10-12 is hopefully non fatal.
Gauge is just showing 40-60 at all times no matter what. So dumb. But I should have expected it.
I really thought it was a real number since it DOES move with rpm. That’s just… tricky. deceitful. rude.
If you have that other wiring left over let me know. It’s cheap to get just a pressure sensor but the extra interface for sensors is $177 itself. Silly. Too bad I can’t just make the dash gauge tell truth - but the dash is definitely failing intermittently so maybe better to bypass it anyway.
