Author Topic: High Miler  (Read 302556 times)
Re: High Miler
« Reply #780 on: December 03, 2023, 09:31:27 PM »
What I bought to get me the sensors will leave me with that same EGT kit as spare/resell. hoped to recoup a couple bucks for a kit that costs the same total as just a pressure sensor and sensor interface.
Re: High Miler
« Reply #781 on: January 02, 2024, 04:39:25 PM »
Have seen this on the overhead twice in the past month.
Codes for fuel level sensor both high and low and CCV . I have a ccv filter on the shelf,
See it that fixes or if it’s the purge valve.
Re: High Miler
« Reply #782 on: April 04, 2024, 08:15:09 AM »
Changed the pcv filter before a trip last week and got the same service message once since.
Fuel gauge will read at full only, still. Guess fifteen year old half million mile trucks need som attention here and there.
Re: High Miler
« Reply #783 on: July 15, 2024, 07:57:17 PM »
four coated reman calipers and new front and rear pads ordered.
Once I pull it in, will I regret not ordering flex lines and rotors immediately? Will I find crunchy brake lines anywhere?
You'll all be the second to know.
Re: High Miler
« Reply #784 on: July 20, 2024, 09:49:03 PM »
Fail: no 8x6.5 adaptor on the on car brake lathe.
I don’t have an 8 lug rotor in scrap to make one from either. Damnit
Re: High Miler
« Reply #785 on: July 21, 2024, 01:01:38 AM »
First rotor off and mildly sketchy setup was about to be tested. Idler motor on the 3 phase converter shit out while I was trying to true up the rotor.
 One scored rotor pulled to be replaced, rest fine to run as is. Humbug
Re: High Miler
« Reply #786 on: July 21, 2024, 01:02:16 AM »
Need an extended cutter head for drw spacing on the lathe too
Re: High Miler
« Reply #787 on: July 21, 2024, 09:19:38 AM »
sounds like a sweet time
High Miler
« Reply #788 on: July 21, 2024, 01:53:38 PM »
463,581
Oil and filter
Tires rotated
Transmission topped off. May be leak from breather or top cover. Something high. May also need output seal.
I changed valve cover gasket a while ago and checked bolts recently when I did the PCV filter. Looks like that is still leaking at the back.
4 new calipers and new left rear rotor.
2 calipers were bad. I could have not done the right rear, it was newer. Other three could have been original
Left rear was to metal plus a bit. Never squealed but braking performance had been shitty.
I’ll have to see if I (or we, maybe someone without a broken 3ph converter and dead machine shop?) can make a longer cutter arm and make an 8 lug adaptor for the on-car brake lathe out of this bad rotor. Smike did you end up with a spare 10 lug or Ford pattern 8 lug rotor? Probably easier to drill new patterns in one rotor and adapt to the lathe.
« Last Edit: July 21, 2024, 01:59:08 PM by mr.mindless »
Re: High Miler
« Reply #789 on: July 21, 2024, 02:12:33 PM »
That's impressive mileage!
Re: High Miler
« Reply #790 on: July 21, 2024, 05:08:45 PM »
Hasn’t stopped this well in probably 5 years. Full success.
Testing tomorrow.
Re: High Miler
« Reply #791 on: July 22, 2024, 10:16:02 PM »
Tested well. I hurt an abs sensor though: abs light and no cruise :(
Bit heavy. Especially with empty tanks. I may consider flipping and downsizing a hair. Price and condition were right. Done vacuuming. Needs a few interior trim pieces fixed and the floor under the plumbing needs a bit of work.
Probably do a fresh thread on it.
Picked up outside Mansfield PA. Got just over 20mpg on the way down by the overhead. Just under 14 coming back up.
I changed the front tiedown to near vertical with a tiny bit rear after the picture. It’s on stall mats and moved around less than half an inch.
Re: High Miler
« Reply #792 on: July 22, 2024, 11:02:36 PM »
Stepping up the camping game!
Re: High Miler
« Reply #793 on: July 23, 2024, 04:51:41 PM »
o boy
of course you needed another thing lol
Re: High Miler
« Reply #794 on: August 10, 2024, 04:29:43 AM »
I've had spare key blanks since I drove this thing to Hammers. Finally cut them and have 2 spare keys that'll unlock the truck. One in the camper and one staying in my keys at home.
Won't start it but will at least turn the ignition on and unlock steering too...
I was going to quote reply a post from how long ago? 6 years? 8? but I guess I never complained about it. Lowes refused to copy my key since it has a chip. Store manager wouldn't do it. I bought 2 blanks and they sat ever since, never cut them. I bought this, and the first one took a few tweaks and close looks; the second I had in one edit. Not a terrible job when you understand what the key is actually doing.
https://www.amazon.com/dp/B0CRZ32Q1V
