Author Topic: High Miler  (Read 301929 times)
Re: High Miler
« Reply #645 on: April 28, 2018, 04:02:30 PM »
ma mopar runs ATF+4 in these things.
Typical fuck mike's life finding: input shaft is missing a tooth again. all parts departments closed so can't check local price/availability.
if I'm lucky I can have one Tuesday, and then get to assemble and install the whole fucker instead of just filling it with oil.
Re: High Miler
« Reply #646 on: April 28, 2018, 05:09:38 PM »
Better and better.
Re: High Miler
« Reply #647 on: April 29, 2018, 11:59:26 AM »
$125 to ship next day from pure diesel power (Wisconsin) to get an input shaft here tuesday. $375 to my door for a shaft and bearing.
We'll see what Dodge can do first thing Monday.
AMP Distributing, who I bought parts through previously, doesn't offer next day on their web site. Priority mail 2 day for $13. sigh.
Piss poor planning is my middle name!
Shaft: g56-16a (3 ID rings, 28 tooth)
Bearing: 32210
Re: High Miler
« Reply #648 on: April 30, 2018, 10:13:08 AM »
Here’s an easy way for that parts list to get out of hand on your dealer repair, mike:
Re: High Miler
« Reply #649 on: April 30, 2018, 10:33:08 AM »
oof
hopefully you talked to a human in Wisconsin and got shipment confirmation over the phone.
Re: High Miler
« Reply #650 on: April 30, 2018, 10:38:00 AM »
Thanks Brett for sanity checking me and looking at rockauto. Order placed for a USA Standard Gear input shaft. Fingers crossed.
Wondering if I should get something better on a slow boat for when that twists so I have it on the shelf.
Re: High Miler
« Reply #651 on: April 30, 2018, 10:52:41 AM »
No problem!
Re: High Miler
« Reply #652 on: April 30, 2018, 11:19:39 AM »
Thruway spring saved my day. 20t prop would have been enough if we took the hidden snap ring off. Under the bearing.
Mechanic who suspected it was there got an extra tip from me. Coulda really ruined my day if not for him!!
Re: High Miler
« Reply #653 on: April 30, 2018, 11:23:50 AM »
Hunt for a complete G56 so you’ll have a complete unit on hand to swap? IMHO the original case is compromised. Cracked & welded, repeated failures.
Re: High Miler
« Reply #654 on: April 30, 2018, 11:25:31 AM »
wasnt it just an ear welded though?
use, tune, gearing, HP is probably more of the problem.....
Re: High Miler
« Reply #655 on: April 30, 2018, 11:29:26 AM »
o shit!
Re: High Miler
« Reply #656 on: April 30, 2018, 11:35:34 AM »
looks like 2500$ with a 600-1000 core with good case halves
most dont warranty "broken gears"   WTF else is there to warranty in a manual?
Re: High Miler
« Reply #657 on: April 30, 2018, 11:37:46 AM »
rock auto doesnt list an input shaft for my truck, thought it was same?
Re: High Miler
« Reply #658 on: April 30, 2018, 11:45:55 AM »
RockAuto don’t list everything for some reason. Need to search the part # then it’ll show up. Since the dealer listed the part # for MikeMike’s G56 so it’s probably safe to assume they does interchange.
Re: High Miler
« Reply #659 on: April 30, 2018, 12:26:49 PM »
and driving style (related to long gearing). Will run with high RPMs from here. May generally tow in 5th, it made nearly no difference in economy - though I did run I think 62-63 in 5th as opposed to 68ish in 6th.
I would expect it to be the same. Does rockouto show you truck at all? cross reference for the USA Standard part I bought only shows 2500 & 3500 trucks 2007-2018.
I believe all neccessary bits will arrive tomorrow.
oil
input
input bearing
front countershaft bearing just found on amazon (cage bent with 3 jaw puller)
Slap shit together, I think I will need to check countershaft shim clearance with the gold plated jig since I'm changing a bearing, oil it, install it.
Mike, you good on that tractor fetch for me tomorrow? I put a caliper on the trailer yesterday and safety wired all the bolts. None of the others were loose at all.
