Author Topic: 1973 CJ6  (Read 172259 times)
« Reply #405 on: June 26, 2014, 11:24:51 AM »
forgotten!
« Reply #406 on: June 26, 2014, 11:31:07 AM »
I did the full firewall where engine heat would migrate...
rated at 1100* direct heat..
valve cover no longer an issue with stock profile units.. also set the body high enough I have room to run a fuel line :)
« Reply #407 on: June 26, 2014, 12:48:57 PM »
Fuel lines are useful
« Reply #408 on: July 02, 2014, 11:07:45 AM »
need to start tackling nitty gritty....
punch list:
Ebrake pedal mount/mock
Drill E brake cable hole
Speedo cable hole
Steering shaft (shock mount interference)
Fuse block mount and drill hole
Brake lines to prop valve
Brake MC Linkage pin
Fuel lines (hard to rubber/TBI)
Heater hose hookup motor to bulkhead fitting
« Last Edit: July 20, 2014, 09:36:28 PM by rejeep »
« Reply #409 on: July 02, 2014, 12:46:45 PM »
i had to trim 1/2" off Eds TDK frame for steering shaft clearance
« Reply #410 on: July 02, 2014, 01:33:13 PM »
I figured I would have to do some trimming...
« Reply #411 on: July 06, 2014, 10:27:40 AM »
Column and steering shaft mounted...
both upper and lower U joint turning nicely with no bind..
the Borgeson shaft is really a nice unit.. Steering feels tight and no play in wheel.
had to remove the inner side of the shock mount for good clearance..
cut the stud right behind the upper shock mount and removed the inner upright brace.
need to grind down rough cut edge and re coat with zinc.
no apparent issue at right height and slight suspension movement..
wont be able to test full frame flex just yet, but from pictures I have seen of others I should be good.
« Reply #412 on: July 21, 2014, 09:21:56 AM »
Brake and Fuel lines plumbed and routed
Fuse block and Howell Harness mounted and routed..
wiring to commence...  :o
« Reply #413 on: July 21, 2014, 09:25:04 AM »
need to start identifying systems and make punch lists as such...
too many loose ends can happen otherwise...
Want to fully button up cooling system this week..
-Shroud
-Rad hoses
-engine hoses to bulkhead
Need to test fit fenders before sending to paint
« Reply #414 on: July 21, 2014, 09:33:26 AM »
those are some sweet slinkys you have there
« Reply #415 on: July 21, 2014, 09:35:43 AM »
expansion and cooling.... plus extra line if ever needed..
« Reply #416 on: July 21, 2014, 09:59:48 AM »
Im used to 2 turn slinkeys, I like it though :)
« Reply #417 on: July 21, 2014, 01:43:26 PM »
fenders installed at lunch...
need to get proper grill spacing for fan shroud and hoses...
tony
  • Come and take it
« Reply #418 on: July 22, 2014, 09:40:26 AM »
Sick toy.  Eta?
« Reply #419 on: July 22, 2014, 02:06:22 PM »
depends on how long the kids nap for
