Author Topic: 1973 CJ6  (Read 172306 times)
« Reply #420 on: July 24, 2014, 10:45:04 AM »
mounted the fan shroud last night,
needed some trimming due to the larger body mounts and its a really form fitting to the rad inlet and outlet..
Trimmed the lower portion bit where the fan was hitting..
« Reply #421 on: July 24, 2014, 11:40:39 AM »
needs paint.. but starting to look like a Jeep...
« Reply #422 on: July 25, 2014, 10:32:15 AM »
That's a nice blue
« Reply #423 on: July 25, 2014, 01:11:23 PM »
AMC medium blue metallic...  love it and its my first blue vehicle ever.
« Reply #424 on: July 25, 2014, 01:18:31 PM »
kinda like my scrambler blue without the metallic
« Reply #425 on: August 01, 2014, 09:07:53 AM »
I made a heater hose last night....
lot accomplished..
carchameleon
« Reply #426 on: August 02, 2014, 11:45:25 PM »
awesome, looks great
« Reply #427 on: August 04, 2014, 08:56:37 AM »
the cluster has started
« Reply #428 on: August 05, 2014, 12:15:42 PM »
I thought you had a serpentine belt system?
« Reply #429 on: August 05, 2014, 01:30:35 PM »
Was thinking about it..
Went with the. Vbelt for ease of repair/parts availability..
Nothing like being stuck somewhere when you have a "1 of" system and need to special order custom parts..
Everything on this truck can be repaired with off the shelf
« Reply #430 on: August 05, 2014, 08:47:30 PM »
That's why I stayed v belt also.
Looking good.
« Reply #431 on: August 06, 2014, 11:14:12 AM »
on a suggestion from my wife I actually looked at the instruction manual last night for the painless kit.... I now understand why they call it painless...  the instructions actually make sense and answer questions...
manhood slightly insulted, yet thankful for female intervention...
« Reply #432 on: August 10, 2014, 12:02:48 PM »
Arie, keep seeing this and think "arie needs this".
« Reply #433 on: August 19, 2014, 11:51:33 AM »
Nothing in the way of major progress has gotten completed..
Summer weddings and sunshine has put a damper on spending some quality time wiring..
hard to get anything done in and hour when the first 20 min is spent figuring out where I left off..
planning on taking a day off of work in the near future to get the thing all routed and termed... I can then spend in between time making it look pretty..
Did get everything grounded and installed a ground block on the firewall for all the dash items.  that 10 ga wire coming off the neg battery term goes right to the dash block.
« Reply #434 on: September 02, 2014, 08:17:41 AM »
Some final to do list....
primed the motor last night 60 psi
hooked up the battery and things came to life....
