Author Topic: Moose  (Read 74198 times)
Re: Moose
« Reply #255 on: July 29, 2013, 10:50:01 PM »
Its a 3/4" line. Only option for my pump. Its not a gm pump like everyone else uses.
Re: Moose
« Reply #256 on: July 29, 2013, 10:50:30 PM »
9.7 or 11.3 range  will need a pump 5 GPM
Re: Moose
« Reply #257 on: July 29, 2013, 10:50:43 PM »
I will look at that tomorrow.  Thanks Gif.
Re: Moose
« Reply #258 on: July 29, 2013, 10:52:25 PM »
The higher number is more flow,  right?  I want a lower number.
Re: Moose
« Reply #259 on: July 29, 2013, 11:04:23 PM »
yes higher number = need more flow = less turns lock to lock
Re: Moose
« Reply #260 on: July 30, 2013, 09:32:09 AM »
I look and I have a 200cc orbital, thats way too much, so I am looking at a 100cc (6.1ci) or 125cc(7.6ci) to replace it prolly the 125cc is the best choice, thats what I ran on both the last buggies without issues.
Re: Moose
« Reply #261 on: July 30, 2013, 04:40:24 PM »
i have one im not gonna use its a eaton 211-1007-001 i cant find much info on it myself
Re: Moose
« Reply #262 on: July 30, 2013, 04:45:47 PM »
nm, found it ,looks like it might be a little smaller than your looking
211-1007 Char-Lynn. Hydraulic steering control unit, Eaton Char-Lynn (Charlynn) 6 Series, 4.5 in3 displacement, (4) 3/8"-16 mounting holes on 3-1/4" bolt circle, 12-tooth internal spline accepts steering column, non-load reacting, 4-8 gpm flow range, #8 SAE oring ports, Eaton Char-Lynn (Charlynn) 211-1007, 211-1007-001, 211-1007-002, 211-1007-003 or latest revision, replaces Baker 117959, Yale 131793404, Yale 501179501
Re: Moose
« Reply #263 on: July 30, 2013, 04:56:21 PM »
the one i got for 572 off ebay for 115$ shipped new in PSC box with the 4 fittings is a 160cc/9.6ci
hope that works
Re: Moose
« Reply #264 on: July 30, 2013, 04:59:20 PM »
4.5ci sounds small even for a 2" ram
Re: Moose
« Reply #265 on: July 30, 2013, 05:14:05 PM »
mine is 6.1 c.i/rev. for 2.7 turns lock to lock with a 6" ram
Re: Moose
« Reply #266 on: July 31, 2013, 09:03:23 AM »
X2
Re: Moose
« Reply #267 on: July 31, 2013, 09:09:54 AM »
Did you get your orbital from Jon on Hardline? If so, Seems like he should've spec'd out the correct one for you. Maybe it was hard to judge unknown Hyundai engine power steering pump psi?
Re: Moose
« Reply #268 on: July 31, 2013, 10:23:20 PM »
Got some new bling for this guy.
Re: Moose
« Reply #269 on: August 01, 2013, 09:18:16 PM »
Wheel spacers installed. Shocks have been "tuned"
