Author Topic: Moose  (Read 74199 times)
Re: Moose
« Reply #270 on: August 03, 2013, 08:56:49 PM »
Troys orbital works perfectly, 3 turns lock to lock.
Checked the part number on the one I took out, its 160cc. $225 if anyone here wants it.
Re: Moose
« Reply #271 on: August 04, 2013, 01:17:35 PM »
Awesome,glad it worked out.idk if you used the fittings on it but I forgot to tell you that black one I beleive is a check valve if that matters at all
Re: Moose
« Reply #272 on: August 04, 2013, 01:57:48 PM »
Hmm, I did use them, I should check that out.
Re: Moose
« Reply #273 on: August 21, 2013, 08:22:15 PM »
Took this thing out for a test run at our land today. Changing the valving in the shock helped a ton, its smooth and floats along the bumps. It rides awesome. Topped out at 35mph full pedal to the floor. OD id not active so thats just 3rd gear.
Steering is good, cooling is good, brakes work good can lock up all 4 in the field. Still gets a little warm in the cab, but thats life in a buggy.
Flexed it out and it does not hit the tires anymore on the chassis.
She is ready for the weekend.
Re: Moose
« Reply #274 on: August 21, 2013, 08:23:05 PM »
Motorhome needs a water heater replaced, have the new water heater, just need some fittings and it should be good. 2-hour job, I hope.
Re: Moose
« Reply #275 on: August 21, 2013, 09:01:29 PM »
Bring it to RC 13-15 !
Re: Moose
« Reply #276 on: August 21, 2013, 09:16:35 PM »
Possible.
Re: Moose
« Reply #277 on: August 26, 2013, 01:15:58 PM »
Fixed and ready for another fine adventure.
Re: Moose
« Reply #278 on: August 26, 2013, 01:27:38 PM »
new end slide in?
Re: Moose
« Reply #279 on: August 26, 2013, 02:00:07 PM »
Spline adjustment is all that was needed.  ;D
It slips like it should now, no more problems. :fingerscrossed:
Re: Moose
« Reply #280 on: August 26, 2013, 02:00:50 PM »
I need to limit that side a little, there are marks on the flanges, adding an internal spacer seems like the best solution.
Re: Moose
« Reply #281 on: August 26, 2013, 02:02:51 PM »
Some burrs or deformation we couldn't see when it was greasy?
Re: Moose
« Reply #282 on: August 26, 2013, 02:04:17 PM »
Yes. Exactly.
Re: Moose
« Reply #283 on: August 26, 2013, 02:16:22 PM »
too bad no one told you that :o
Re: Moose
« Reply #284 on: August 26, 2013, 08:27:47 PM »
fixed what?
