Author Topic: Time for Tons  (Read 125919 times)
Hannah
  • Full Member
Re: Time for Tons
« Reply #540 on: April 02, 2016, 07:01:59 PM »
Re: Time for Tons
« Reply #541 on: April 02, 2016, 07:11:02 PM »
looking good!
Re: Time for Tons
« Reply #542 on: April 02, 2016, 07:47:01 PM »
Don't have full steering at full stuff, but they rub on smooth surfaces so fine for now.
Just about ready for Big Dogs
Time for Tons
« Reply #543 on: April 09, 2016, 06:38:42 PM »
Decided to rework bumper in order to make a little room to stretch the front a bit more to get the tire out of that fender tube at full stuff when turning.
Will finish other side tomorrow. Also need to move shock mounts on axle outboard of current mounts, pass side shock was bending from interference with unibody rail at full droop.
Re: Time for Tons
« Reply #544 on: April 09, 2016, 06:56:21 PM »
Working overtime to keep it Cherokee!  ;D
Re: Time for Tons
« Reply #545 on: April 10, 2016, 06:31:52 PM »
Reworked bumper tube and 3/4" stretch made lock-lock possible at full stuff on pass side, driver side saw an improvement but still rubs a good amount on the fender tube. Nothing obviously different side-side throwing a tape measure on multiple things. Difference in trackbar arc depending which side is up/down? Not sure, but living with it for now.
Re: Time for Tons
« Reply #546 on: April 10, 2016, 07:08:11 PM »
Track bar will change things significantly. Passenger stuff moves the axle to passenger, passenger drop moves axle to driver.
Re: Time for Tons
« Reply #547 on: August 15, 2016, 08:59:00 AM »
Both front axles torn down and reassembled yesterday. Probably drank two gallons of water and it still probably wasn't enough.
Rear driver caliper bracket had broken so that was replaced and prototype Torq locker was reinstalled for good after being sent out for inspection.
Front end had a Torq unit installed as well. Found backlash a bit loose, driver upper ball joint loose (still Moog junk never changed from initial swap on that side) and pass side wheel bearing sounded pretty rumbly during tightening.
Wheeling the next 3 out of 4 weekends so hopefully <200hp and low speed will keep it alive! Probably looking at a full tear down again this winter to remedy all. Lot of work with steering attached to cover.
On the plus side, I am very much looking forward to being able to steer in driveways or parking lots!
Re: Time for Tons
« Reply #548 on: August 15, 2016, 02:40:15 PM »
First pic of this page looks so awesome.  I dig it more than any buggy.
Re: Time for Tons
« Reply #549 on: August 15, 2016, 10:40:19 PM »
Thanks M! If only it wheeled like a buggy...
Hannah
  • Full Member
Re: Time for Tons
« Reply #550 on: August 29, 2016, 10:17:31 PM »
Some highlights from Field and Forest this weekend. Pretty insane red trails out there.
Hannah
  • Full Member
Re: Time for Tons
« Reply #551 on: August 29, 2016, 10:20:20 PM »
Last hill climb at end of "Easy Street" with a buggy after H for comparison
Re: Time for Tons
« Reply #552 on: August 30, 2016, 08:06:19 AM »
looks awesome
Re: Time for Tons
« Reply #553 on: August 31, 2016, 10:10:23 AM »
Awesome video.  The XJ looked like it had a easier time going through that compared to buggy (was he showing off though?)
Re: Time for Tons
« Reply #554 on: October 29, 2016, 11:17:13 PM »
https://youtu.be/WfwnSgePAhs
Will inspect tomorrow, but damage seemed minimal considering how hard the roll.
