Author Topic: Small buggy  (Read 28906 times)
Small buggy
« on: September 10, 2012, 12:46:31 PM »
« Last Edit: October 05, 2012, 10:14:04 AM by Profender »
Re: Grand Cherokee
« Reply #1 on: September 10, 2012, 12:47:19 PM »
Re: Grand Cherokee
« Reply #2 on: September 10, 2012, 12:49:11 PM »
the ZJ in my lot needs and oil pan and some rear axle setup work.  talked to the guy, seems to just want it to sit there and not sell it though.
Re: Grand Cherokee
« Reply #3 on: September 10, 2012, 12:49:58 PM »
Re: Grand Cherokee
« Reply #4 on: September 10, 2012, 09:00:35 PM »
Chad has a zj with blown motor he said $450
Re: Grand Cherokee
« Reply #5 on: September 10, 2012, 09:11:55 PM »
I don't want to work on anything. I'm old and lazy.
Re: Grand Cherokee
« Reply #6 on: September 10, 2012, 10:12:46 PM »
if i was to do it again i would definitely do a niner or a 4.7L WJ
i know you had a ZJ and probably know all this, but i'll just throw it out there.  i didnt know till i had spent years reading/working on Grands
a wj is 63.5 WMS where a ZJ/XJ/TJ is 60. something to consider with an axle swap using, say, a  8.8 at 59.5 WMS (wheel spacers would work and would be needed to convert from 5x5 to 5x4.5
WJs only come with cv shafts in the font axle. if you want ujoints you have to have custom inner shafts made
96-04 Grands with a v8 have the 44a rearend. its safe to 33s locked and 35s locked and trussed. all niners have lsd, some others do. obviously lsd means no aussie. iirc, the shafts are only 0.012" smaller than the 8.8 shafts. problem is the tubes spin in the alum housing.
niners have e-fan stock
most v8s have a 6ball cv joint at the axle end of the front driveshaft. if you lift it over 2 inches you have to convert to a regular ujoint.
orange anchor
Re: Grand Cherokee
« Reply #8 on: September 20, 2012, 01:42:35 PM »
Ryan you should just buy a side by side and a little trailer for behind the durango
Re: Grand Cherokee
« Reply #9 on: September 20, 2012, 01:50:43 PM »
Those things are too expensive.  :'(
Grand Cherokee
« Reply #10 on: September 20, 2012, 02:53:57 PM »
5.9 in Scranton
http://binghamton.craigslist.org/ctd/3239149094.html
Haha the mikes and I were just wheeling off of keyser ave this past weekend.
Re: Grand Cherokee
« Reply #11 on: September 23, 2012, 05:48:29 PM »
Re: Grand Cherokee
« Reply #13 on: September 26, 2012, 09:43:22 AM »
better than a ZJ.
Re: Grand Cherokee
« Reply #14 on: September 30, 2012, 08:19:18 PM »
I really like this, its too much money for what it is.
http://www.pirate4x4.com/forum/misc-stuff-sale/1092422-buggy-project-1800-a.html
