Author Topic: Small buggy  (Read 33663 times)
Re: Small buggy
« Reply #30 on: October 05, 2012, 11:10:21 AM »
Tow rig and trailer time again  :)
he's got the sweet Durango!!
Re: Small buggy
« Reply #31 on: October 05, 2012, 11:18:53 AM »
We already have many trailers, and I can tow it witht he Durango, or pick up if I choose to get another one. Even a GC with a V8 will tow fine.
Re: Small buggy
« Reply #32 on: October 05, 2012, 11:23:02 AM »
so silly
Re: Small buggy
« Reply #33 on: October 05, 2012, 11:23:44 AM »
i will be laughing the first dana30 stub shaft you blow so hard ill have to go take a nap after
Re: Small buggy
« Reply #34 on: October 05, 2012, 11:29:38 AM »
if I was ever to start over I'd go Zuk, 6.5:1 w/toy flanges, toy axles.  Cheap, light, nimble, schrong enough.
Re: Small buggy
« Reply #35 on: October 05, 2012, 11:54:35 AM »
Waggy 44s with Chromos will be plenty strong, Toy with Longs plenty strong too.
The stock Scout 44s on Atom never broke a shaft. The spindles fell off, but the shafts were fine.  ;D
Eroc is a smart man.
Transaxle might be interesting, lighter and more compact. Driveshafts are where I have issues all the time.
Transaxle is alway in a 4:1ish low range, outputs are large enough, driveshaft adapters are non-existant. Either custom made or welding shit up.
Re: Small buggy
« Reply #36 on: October 05, 2012, 12:03:44 PM »
Whole 'zuk.  Enclosed with wipers and heat?  Still cheap and light...
Re: Small buggy
« Reply #37 on: October 05, 2012, 12:05:18 PM »
Liz is scared of Samurais.  :'(
Re: Small buggy
« Reply #38 on: October 05, 2012, 12:07:58 PM »
tracker then?  haha
is zuk tcase the same for auto and standard?
Re: Small buggy
« Reply #39 on: October 05, 2012, 12:08:38 PM »
Samurais never had auto.
They are divorced mount cases, will work on anythign
Re: Small buggy
« Reply #40 on: October 05, 2012, 12:12:39 PM »
sidekick must have then?  i know theres some kind of swap they do
Re: Small buggy
« Reply #41 on: October 05, 2012, 12:16:48 PM »
Track/Kick did have auto, I had one in Atom. 2 wheel drive will bolt in and work on the 1.3. Or make a sweet doubler like we did in Atom.  ;D
Re: Small buggy
« Reply #42 on: October 05, 2012, 12:21:04 PM »
Ah OK.  Divorced toy adapters are few and far between.
Re: Small buggy
« Reply #43 on: October 05, 2012, 01:05:50 PM »
it should be "easy" to use the inner CV joint and part of the axle shaft from the car's axles and adapt to a splined stub on the other end to accept a yoke.
CVs do have some plunge capability to them though, so that could make things interesting and maybe not that easy. Could certainly be the head of a 2 piece on one end, and set up the links on the other end to be the proper geometry that there's nearly no plunge through travel & articulation and just use the CV and no other slip. Could be done but hard to design around.
Re: Small buggy
« Reply #44 on: October 05, 2012, 01:24:00 PM »
This is how they be doin it
