Author Topic: One last time, BANG  (Read 39841 times)
One last time, BANG
« on: August 10, 2012, 01:03:21 PM »
race prep?
what's gotta get done?
I also just posted on FL asking about departure plans...
[/quote]
(1)I have been toying with throwing the PSC ram on for this race, but leaving the mounts for both.  Everything would swap back and fourth to a new car, or its only 300$ in parts meh.
(2)id like to pull the front shocks and put them on the rear, put the new shocks on the front
(3)Front driver bump pad deserves an extention
(4)wash job / new profender decals
(5) mount extra yellow top
(6) fluids changes
(7) check both front king pins / weld up passengerside also
(8) front tool bag mount
(9) mount new highlift
(10) check front shaft everything
(11) grease job
(12) wheel studs
Re: One last time, BANG
« Reply #1 on: August 10, 2012, 08:22:55 PM »
Do you want me to check what springs I have, replace some bent ones?
« Reply #2 on: August 11, 2012, 12:24:53 AM »
have any 250 or 300;s in lower coil size for 14"S?
« Reply #3 on: August 11, 2012, 12:03:23 PM »
I have 250 300 and 325
« Reply #4 on: August 11, 2012, 11:39:28 PM »
race prep?
(6) fluids changes
(11) grease job
(12) wheel studs
front axle seals
reset front diff preload
steering fixed way better, i think it might last more than a lap tight
[/quote]
« Reply #5 on: August 12, 2012, 01:57:47 PM »
(6) fluids changes
(11) grease job
(12) wheel studs
front axle seals
One last time, BANG
« Reply #6 on: August 13, 2012, 09:41:47 AM »
You starting soon after work tonight? I'll be there.
« Reply #7 on: August 13, 2012, 10:03:54 AM »
ill be at the shop at 6, i might try to wash it quick tonight first.
« Reply #8 on: August 13, 2012, 10:04:55 AM »
How does it sit with the new springs?
« Reply #9 on: August 13, 2012, 10:57:14 AM »
not bad, front is good, rear has a lot of preload.
« Reply #10 on: August 13, 2012, 11:17:47 AM »
Less than 3" of preload?
« Reply #11 on: August 13, 2012, 12:06:12 PM »
i started with 1" on the bench which got me 3" of thread showing.  i ended up at 5" of thread showing so ya i got about 3" in the rear, probably 2" in the front
« Reply #12 on: August 13, 2012, 12:08:08 PM »
untill i get tires back on it ill decided if i need to go a little stiffer or not in the rear where my ride height is.  right now i am thinking i am still an inch or so too low in the back.
« Reply #13 on: August 15, 2012, 11:46:40 AM »
(6) fluids changes
(11) grease job
(12) wheel studs
front axle seals
« Reply #14 on: August 15, 2012, 11:48:36 AM »
lots of other things still on the list
found trans mount bolts loose, welds to hold bolts broken!   cleaned and welded again.
