Author Topic: Hows the MJ drive?  (Read 41064 times)
Hows the MJ drive?
« on: January 12, 2012, 02:58:28 PM »
whats up with my giving tree truck?
Re: Hows the MJ drive?
« Reply #1 on: January 12, 2012, 03:45:08 PM »
is one of my friendly competitors dragging his feet :)
heeheee
« Reply #2 on: January 12, 2012, 04:21:15 PM »
my email get lost in the mess??  haha
On 12-Jan, 2012, at 12:58 , Michael Maskalans wrote:
> Seems to just idle rough once warmed up. IAC maybe? Brake pedal sits high
> with dead space at the top.
> All else seems good w it
> Michael Maskalans
> Sent from my iPhone
« Reply #3 on: January 12, 2012, 04:22:50 PM »
Clutch was really agressive right off - new? or maybe just from sitting? it evened out by the time I got lunch.
there was also a couple drips on the floor by the ebrake pedal, little rain water leak somewhere.
« Reply #4 on: January 12, 2012, 04:23:59 PM »
is this the blue one i put a motor in or the other one with new floor boards?
« Reply #5 on: January 12, 2012, 04:33:08 PM »
white longbed 4x4 2.5 4sp with new floorboards
« Reply #6 on: January 12, 2012, 04:33:26 PM »
and stickers
« Reply #7 on: January 12, 2012, 04:39:16 PM »
window seals on old XJ's notorious for leaking...
might need to address that at some point after body work..
clutch was new when new motor went in 25K ago..
prob form sitting..
idle still bad?
« Reply #8 on: January 12, 2012, 04:41:11 PM »
once it's warm it just idles rough. Cold it purrrrrrs, and it drives fine.
may even be idle speed, or it could be mixture (O2 sensors, TPS, IAC), or dirtyness (injectors, plugs, etc - but at 25k that all should be fine)
« Reply #9 on: January 12, 2012, 04:44:17 PM »
sounds like bad o2 if thats the problem in closed loop.
« Reply #10 on: January 12, 2012, 07:00:07 PM »
the long block has 25K.. not all the acc.
« Reply #11 on: January 12, 2012, 08:23:42 PM »
I unplugged the O2. See if it changes anything. Wires on the O2 make it look brandy new, doesn't mean it's good or right though.
« Reply #12 on: January 12, 2012, 08:46:35 PM »
ill have it hooked up the machine when it goes for a sticker ::)
« Reply #13 on: January 12, 2012, 08:55:53 PM »
1989? I don't think so...
« Reply #14 on: January 12, 2012, 08:58:23 PM »
86 vintage...
older than any of you yet????
