Author Topic: Hows the MJ drive?  (Read 41066 times)
Re: Hows the MJ drive?
« Reply #15 on: January 12, 2012, 09:17:34 PM »
Older than Alex, maybe Matt and Harrison too?
« Reply #16 on: January 12, 2012, 09:57:38 PM »
Loose DS outside mirror
Similar vibe/rumble to Beeper at 60ish
Check engine light has to be burned out, it's not lit w no O2 sensor
Idles too slow, but I think smoother? Tough to say.
« Reply #17 on: January 12, 2012, 10:12:58 PM »
Interesting...
Got a scanner.. I'll figure this guy out..
I was just lift shopping.... I'm kinda excited about doing my old MJ...
Deff want to do something different..
Like exo cage, bobbed bed, so,etching different..
« Reply #18 on: January 12, 2012, 10:15:21 PM »
drop it off sometime   ;D   id love to bob one  it will need tons and 37's at least though :)
« Reply #19 on: January 12, 2012, 10:25:31 PM »
Well in theory...
I could take the short bed and pit it on the LB right?
« Reply #20 on: January 12, 2012, 10:32:48 PM »
needs like 2' taken out of the short bed also....
« Reply #21 on: January 12, 2012, 10:34:08 PM »
Hmmm...
Where would the spring hangers go?  Or are we talking coil overs?
« Reply #22 on: January 12, 2012, 10:36:18 PM »
personally id leave it leafs. id have to look and plan it out but the shackles would end up something like right at or just behind the tailgate.
« Reply #23 on: January 12, 2012, 10:39:04 PM »
And the gas tank?  Might get funky under there.
You don't like body work though...
I would have to dust off the old welder...
« Reply #24 on: January 12, 2012, 10:42:33 PM »
i can do anything, but if it involves paint, the paint must be bedliner....
i could get it solid and straight for someone else to prep and paint easy....
« Reply #25 on: January 12, 2012, 10:43:13 PM »
or, just add a stripe where the bob is like eric did on the yota
« Reply #26 on: January 12, 2012, 10:46:52 PM »
Interesting...
Well before I pull the trigger on the old white one..
I'm getting this one up and running well and out it through its paces..
Have to analyze the rust issues, cab corners, and bed... Bit that's not an issue...
I really just miss my MJ... Can't wait to toot around in it..
« Reply #27 on: January 12, 2012, 10:48:23 PM »
Plugged the O2 back in at wegmans and drove home. Unplugged it in the driveway idling rough at home. Zero difference at all. I think it's just idling at 400 once it's warm. Tough to say without a tach.
Runs and drives real nice.
« Reply #28 on: January 12, 2012, 10:50:25 PM »
And rides better than & handles more surely than a certain around town beater of mine.
« Reply #29 on: January 12, 2012, 10:50:45 PM »
Yeah not o2
Couls be the MAP sensor..
