Author Topic: Land Rover 109  (Read 61325 times)
Re: Land Rover 109
« Reply #45 on: June 05, 2013, 09:16:45 AM »
hmm looks not to be- just send two ujoints over to south ill rebuild the old shaft if it needs it
Re: Land Rover 109
« Reply #46 on: June 05, 2013, 09:32:48 AM »
I think I can cross them.. I should have in stock..
Re: Land Rover 109
« Reply #47 on: June 05, 2013, 09:34:02 AM »
ill head down there later with gear oil and 2 sets of joints... it will be one or the other...
Re: Land Rover 109
« Reply #48 on: June 05, 2013, 12:40:57 PM »
cool, this afternoon or after5?
ill be there after 5
Re: Land Rover 109
« Reply #49 on: June 05, 2013, 03:57:29 PM »
yeah ill prob be there @ 5...
Re: Land Rover 109
« Reply #50 on: June 06, 2013, 02:35:22 PM »
correct calipers down at south..
Re: Land Rover 109
« Reply #51 on: June 06, 2013, 04:38:21 PM »
cool, are they open till 5 or 5:30 again?
Re: Land Rover 109
« Reply #52 on: June 07, 2013, 08:37:14 AM »
going to try and swing by before lunch and gran this guy...
did you give it a shakedown run?
Re: Land Rover 109
« Reply #53 on: June 07, 2013, 10:40:46 AM »
rover grabbed...
drove nice on hwy..
brakes need a full bleed...
you didnt need the front hoses?
Re: Land Rover 109
« Reply #54 on: June 07, 2013, 10:57:48 AM »
the kit came with brake lines.
one snapped like a twig when i put the adapter in.
i was happy there was a second set in the box.
was raining i did not test drive.
After all the issues and frustrations i had, i did not even dare look at what was in the rear.
calipers had to be ground on both sides for wheel clearance
your driver knuckle seal or whatever needs to be changed soon.
Re: Land Rover 109
« Reply #55 on: June 07, 2013, 10:58:38 AM »
its probably in 4x4 also, was pulled in and out with front shaft only- check that!
Re: Land Rover 109
« Reply #56 on: June 07, 2013, 11:18:04 AM »
The swivel housing seal??? Around the chrome ball
Figured I'd be in for that soon.
I'm going to do the rear brakes next week and then flush the system with dot5
Re: Land Rover 109
« Reply #57 on: June 07, 2013, 11:21:52 AM »
isn't it DOT5 that isn't compatible with DOT4 and older? I'd stay the hell away and leave oldstuff-compatible fluid in there. That's like running ethanol fuel by choice in something with old seals.
which reminds me, I need to put new seals on the Deere carb again,
Re: Land Rover 109
« Reply #58 on: June 07, 2013, 11:24:17 AM »
not Dot 5 is low moisture... for stuff that isn’t driven all the time.. silicone...
as long as all the dot 3 is out its no issue..
Re: Land Rover 109
« Reply #59 on: June 07, 2013, 01:48:46 PM »
no more tire rub at full lock  ;D
guess that fraction of an inch wider made a difference
