Author Topic: Land Rover 109  (Read 61540 times)
Re: Land Rover 109
« Reply #165 on: September 18, 2015, 08:30:22 PM »
Smile I'm with you.
40 year old shackle bushings are the devils work.
Re: Land Rover 109
« Reply #166 on: September 19, 2015, 03:13:50 PM »
SMike, I would like to personally apologize for even asking you to try and do these bushings...
this is one of those labor of love tasks that only a vehicle owner should even attempt to do...
Re: Land Rover 109
« Reply #167 on: September 19, 2015, 10:36:29 PM »
Lol
Re: Land Rover 109
« Reply #168 on: September 20, 2015, 05:51:59 PM »
drill out rubber, sawsall though sleeve, chisel out sleeve.
They suck
and i even knew what i was in for from my s10.
Re: Land Rover 109
« Reply #169 on: September 21, 2015, 08:45:38 AM »
Yup...
Decided I didn't cut enough on side 1.
Need to hack it up a bit more and grind down some chisel bits for the air hammer.
Re: Land Rover 109
« Reply #170 on: October 02, 2015, 10:02:50 AM »
is a good measurement of castor angle obtained on the top of the kingpin bolts?
Re: Land Rover 109
« Reply #171 on: October 02, 2015, 10:18:09 AM »
probably the best you can do ya
Re: Land Rover 109
« Reply #172 on: October 05, 2015, 08:26:11 AM »
Truck is on the road today...
New shocks F/R
4* shims to correct castor angle
Pics to follow...  (warning. will all be parking lot shots with a twist)
Re: Land Rover 109
« Reply #173 on: October 05, 2015, 10:35:41 AM »
Ive only been able to drive to CVS and to work, but my initial impression is it rides better & sits higher..
What I ended up with:
-RANCHO 7000 series shocks.. they are monotube with a brushed zinc coated housing.. they look sharp.
  Nice firm ride for a top heavy narrow track truck
-Poly frame bushings and traditional metal/rubber in the springs.
-Military shacks in the front, standard ones in the rear..
-4* pinion shims to correct steering.. after 250 miles i'm going to alignment shop to have true readings taken.
Truck sits nice and level now.. we will see how the springs "break in" over time..
Still on the suspension to do list..
- Notch crossmember for front DS (still removed from truck)
- watch rear shocks with full load in rear.. (might have too much extension and not enough compression room)
- if this were a Jeep I would be looking for a high steer option.. don't know if there is anything like that in the rover world.
- throw a few tack welds on the shims to perches
« Last Edit: October 05, 2015, 10:37:47 AM by rejeep »
Re: Land Rover 109
« Reply #174 on: January 20, 2016, 09:30:39 AM »
Winter work:
Stock PCV setup
Koenig
Fuel pump (NOS)
New Front DS, possible frame notch required
Tcase shifter anti rattle clip
Fluids
valves
exhaust
« Last Edit: January 20, 2016, 10:22:44 AM by rejeep »
Re: Land Rover 109
« Reply #175 on: February 19, 2016, 08:42:53 AM »
finally...
Re: Land Rover 109
« Reply #176 on: February 19, 2016, 09:15:58 AM »
That's awesome!  Must hold 1000' of cable too.
Re: Land Rover 109
« Reply #177 on: February 19, 2016, 09:44:37 AM »
Love this thing!
Re: Land Rover 109
« Reply #178 on: February 19, 2016, 11:05:46 AM »
PTO right?
PTO is so fun, love the shovel winch / boom
Re: Land Rover 109
« Reply #179 on: February 20, 2016, 09:39:29 AM »
Front crankshaft driven PTO...
of course my engine didn't have the correct crank pulley.. NOS part from some desert country
the adapter flange is still obtainable reproduction
Had the driveshaft made by a forum member down in NC..
still need to work on the correct keyway for the winch end of business.. but it was enough to spool the cable..
Still to do:
-need to create an engagement handle lock...
 (last thing i would need is some idiot playing with it in a parking lot and I take off and the winch sucks my truck inside itself
-tow point on bumper
-need to fabricate winch clamps for the rear frame mount...  Have and original to copy..
some pictures of the crank adapter, driveshaft (hole through front frame) and original sees procure so you can get an idea of whats going on there...
lost the ability to hand crank engine... need a new battery :)
