Author Topic: 571 overhaul  (Read 62586 times)
571 overhaul
« Reply #60 on: February 27, 2012, 04:50:50 PM »
It can't be half as bad as a square shaft
Re: 571 overhaul
« Reply #62 on: March 01, 2012, 01:03:27 AM »
I still don't love 0.375" wall.... But overkill is the best kind of kill, right?
Re: 571 overhaul
« Reply #63 on: March 01, 2012, 06:42:48 AM »
yes.   Gona see if they have anything at SMC loose, if not just gona order that.
Re: 571 overhaul
« Reply #64 on: March 01, 2012, 12:57:10 PM »
Only problem with beefing up the shaft that I see is that it moves your weak point somewhere else. Def will hold up better to being ground against rocks and whatnot though!
571 overhaul
« Reply #65 on: March 01, 2012, 01:02:00 PM »
Only you jeep people need to build in weak points :P
Re: 571 overhaul
« Reply #66 on: March 01, 2012, 01:06:35 PM »
rather have a weak point and know what it is than live and wonder how weak a vehicle I am driving
571 overhaul
« Reply #67 on: March 01, 2012, 01:26:17 PM »
That's a glass half empty statement if I've ever heard one
Re: 571 overhaul
« Reply #68 on: March 01, 2012, 01:36:07 PM »
 ;D
571 overhaul
« Reply #69 on: March 01, 2012, 01:43:31 PM »
Pinion or output will snap. That's easy :)
Re: 571 overhaul
« Reply #70 on: March 01, 2012, 06:42:43 PM »
no way a 14 bolt pinion is caring, you might round off the yoke ears on rocks but not much else.  Never herd of a 205 failing in any way so im not worried.
i got 400lbs or so of steel, got some pieces of tube for driveshaft, but not sure ill use them, not a nice fit, a little loose.
Re: 571 overhaul
« Reply #71 on: March 01, 2012, 06:54:52 PM »
solid knuckles, highsteer arms, caps in the mail....
orange anchor
Re: 571 overhaul
« Reply #72 on: March 02, 2012, 08:07:35 AM »
Smile what you doing old knuckles I got a chevy frt 60 I might want to convert
Re: 571 overhaul
« Reply #73 on: March 02, 2012, 11:30:15 AM »
I think these are going to stay with this axle for now, probably building a second housing...
Re: 571 overhaul
« Reply #74 on: March 03, 2012, 11:01:04 PM »
HD
