Author Topic: 571 overhaul  (Read 62704 times)
Re: 571 overhaul
« Reply #45 on: February 15, 2012, 01:51:32 PM »
Looks like a 4" and 4.75" backspacing are listed in the catalog.
Re: 571 overhaul
« Reply #46 on: February 15, 2012, 02:59:25 PM »
H2's are 5 5/8" so a 4.75 should work for you.
ill be driving over my trailer fenders, with 4" probably you will too
Re: 571 overhaul
« Reply #47 on: February 15, 2012, 03:01:32 PM »
Ok, then 4.75 it is.
Re: 571 overhaul
« Reply #48 on: February 25, 2012, 02:43:51 PM »
Looks like its time for a new shaft too.
Re: 571 overhaul
« Reply #49 on: February 25, 2012, 02:55:01 PM »
facebook?
571 overhaul
« Reply #50 on: February 25, 2012, 03:15:31 PM »
Overdue.
Re: 571 overhaul
« Reply #51 on: February 26, 2012, 01:54:56 PM »
highly overdue.  on of the red climbs out of cemetery got me.
Re: 571 overhaul
« Reply #53 on: February 26, 2012, 07:26:12 PM »
Wont something that heavy destroy your output and pinion shafts?
Re: 571 overhaul
« Reply #54 on: February 26, 2012, 08:28:22 PM »
i dont think there will be any issues
orange anchor
Re: 571 overhaul
« Reply #55 on: February 27, 2012, 08:32:33 AM »
Smike think about the spinning mass of that tubing,  call OEM he got the right stuff in stock.
571 overhaul
« Reply #56 on: February 27, 2012, 09:04:10 AM »
.250 is the thickest I'd go and really should be plenty.
I broke parts when I had a .180 wall shaft before I damaged the tubing.
orange anchor
Re: 571 overhaul
« Reply #57 on: February 27, 2012, 09:10:13 AM »
at race speeds too thick of drive shaft will destroy the u-joints and pinion bearings.
Re: 571 overhaul
« Reply #58 on: February 27, 2012, 12:09:26 PM »
im not really understanding the physics behind that, assuming the shaft is relatively balanced....
I can build it myself for less that what it costs me to drive out there twice in diesel and lost work time  :/    i know he makes good stuff, its just really hard for me to make it happen.
orange anchor
Re: 571 overhaul
« Reply #59 on: February 27, 2012, 12:22:14 PM »
Smike I think it has to do with centrifigual force.  Force= mass * acceleration. nothing is ever perfectly balanced therefore what is out of balance should weigh the least possible.  I am not pushing OEM, just made a suggestion.
