Author Topic: 572  (Read 366262 times)
Re: 572
« Reply #120 on: June 15, 2012, 10:30:03 AM »
It could be a rental, Mike, Matt, ALex, or anyone could rent it for a race. Hahahahahah
« Reply #121 on: June 15, 2012, 10:36:09 AM »
572 trailer?
Re: 572
« Reply #122 on: June 15, 2012, 11:58:28 AM »
Rental with 12k deposit, and 3K prep fee, sure
Re: 572
« Reply #123 on: June 15, 2012, 05:44:32 PM »
more to the pile....
[attachment deleted by admin]
Re: 572
« Reply #124 on: June 15, 2012, 11:24:05 PM »
that cant be all of a $900 order,wheres the rest of it
Re: 572
« Reply #125 on: June 16, 2012, 01:23:36 AM »
check your math there troy, that is all of it.
lots o 1.25" heims adds up quick.
Re: 572
« Reply #126 on: June 16, 2012, 07:41:17 AM »
oooo, shiney!  :)
Re: 572
« Reply #127 on: June 17, 2012, 10:07:14 PM »
I'm gone most of this week if you wanted to meet up for paperwork.. I know you work fast.. Didn't want a hulk sitting there longer then my MJ
Re: 572
« Reply #128 on: June 17, 2012, 10:16:11 PM »
ill probably pull the motor out next week.  seems to run fine.  ill part a few things out.  Dont really need paper work, but sure.  whats left will end cut up in the back of a pickup.
Re: 572
« Reply #129 on: June 17, 2012, 11:35:23 PM »
i need to take some time to get over to M4 and see whats a brewing.
Re: 572
« Reply #130 on: June 30, 2012, 10:43:47 PM »
express van cut up, monday will be a scrap day!
Re: 572
« Reply #131 on: July 03, 2012, 10:07:20 AM »
Have on the shelf:
5.3 motor
4l60e trans
Ford 205 case
axles
rear disc brackets
2.5Co's
480' of 1.75" tube
6 pairs of 1.25 heims
6 pairs f 7/8" heims
PSC 2.5 x 8 ram
drive train bushing mounts
2 volvo fans
brake / gas assemblies / booster MC's
KRTS on H2s
Aluminum for roof
2" carrier bearing
drive shaft parts almost
rear mirror
2 sway bumps
exhaust parts
yellow top
gazilion 3/8" link tabs
Need:
ECM flash
radiator
8:1 exhaust hehehee
fuel cell
orbital
hydro lines
seat
harness
trans cooler
steering cooler
link material
MS disco
knuckles / arms / front shafts/drive slugs/stage8's
rear disk hardware
wheel / column
winch
horn
lights
gages
Belly HDPE
GPS
window nets
not running a sway bar
not running a spare tire
« Last Edit: July 03, 2012, 10:13:10 AM by M4wdFab »
awl4928
  • Sr. Member
Re: 572
« Reply #132 on: July 03, 2012, 10:23:55 AM »
No spare tire?   Are you planning to.just drive back to the pits on a whooped tire?
« Reply #133 on: July 03, 2012, 10:26:11 AM »
8:1? I'm not rec wheeling with this pile ;)
Re: 572
« Reply #134 on: July 03, 2012, 10:28:01 AM »
I think you need to run a sway bar and shorter shocks, at least on the rear trailing arms.
