Author Topic: 572  (Read 413142 times)
Re: 572
« Reply #705 on: September 07, 2013, 11:00:27 PM »
gps in
winch control mounted in dash
tack installed, but i guess i need a resister and white wire pin 10 for 03+ ECMs to work
tins cal''d up
Re: 572
« Reply #706 on: September 15, 2013, 09:06:13 PM »
flogged the shit out of this car several times this weekend, it refuses to fail.  i am pleased.
couple small known issues that occurred
popped rad hose that was exposed, new aluminum straight neck in hand
bent rear mid shaft ( pillow block needs to move further back and shaft material upgraded
broke limit strap eye day 1 obstical 1, possible mounting issue
PSC ram loose internally
left header flange contacts plug boots cracked a plug, coil is grounding out somtimes- meh
slammed knee on orbital mount in otters trail, need to fix or move or pad better, no good.
front suck down loop broke off, needs more steel
bent front track bar, needs more wall
several rock bounce attempts inside shoot the moon exit, had to turn Rs in mudd with bounce assaults on right side.  that trail is nuts now.
All 3 cars made it up both talismans today.  i gave up on lower, then gif and jeff made it, so i hit it harder and made it barely with lots of Rs and smoke
front end needs more shock tune too bouncy going slow
Re: 572
« Reply #707 on: September 17, 2013, 11:18:33 AM »
I watched the flogging 572 took.  It was impressive.   I have to say, I have never seen a burnout on a tree that was still standing with a wheel that was 5 ft up it before.   We need to start taking more videos.   ;)
Re: 572
« Reply #708 on: September 17, 2013, 01:24:57 PM »
flog by brail to where the traction is....
Re: 572
« Reply #709 on: September 20, 2013, 03:51:24 PM »
Failed TG strap Rc47 bolt ends
Re: 572
« Reply #710 on: September 20, 2013, 10:59:23 PM »
i guess "it'l be fine" is no longer good for my wreck wheeling style.  Chassis welds broke in 5 places around rear end....always knew it needed more tube, just didnt think it needed it for a RC wreck wheel trip....
Re: 572
« Reply #711 on: September 21, 2013, 07:50:01 AM »
The buggy weekend was pretty intense...
Re: 572
« Reply #712 on: September 21, 2013, 10:52:05 AM »
Wow. That's surprisingly many
Re: 572
« Reply #713 on: September 21, 2013, 11:38:52 AM »
Re: 572
« Reply #714 on: September 21, 2013, 11:44:52 AM »
we are not nice to the buggies  8)
define welds broke.   I would think the material next to the welds broke.  your welding looks good.
Re: 572
« Reply #715 on: September 21, 2013, 07:16:58 PM »
ya material failed next to welds
Re: 572
« Reply #716 on: September 21, 2013, 07:20:38 PM »
https://www.youtube.com/watch?v=zjED522hsW8
that was me wreck wheeling.
then you and jeff had to hawg your way up so i hit 10 times more 3x harder and made it lol
Re: 572
« Reply #717 on: September 21, 2013, 07:41:30 PM »
someone asked me if there were plans to build my buggy from today hahaha
Re: 572
« Reply #718 on: September 23, 2013, 11:13:48 AM »
broken material ground out / re welded.  6 or 7 tubes notched in and tac'd up.  good start about half way to rear end finish.
F Mud.
orange anchor
Re: 572
« Reply #719 on: September 23, 2013, 12:21:40 PM »
I feel like we are just driving around looking for something to break the buggies.  In one day of "Wreckage Wheeling" I broke a CV, Front stub and rear axle shaft. Boy, did we have fun though.
