Author Topic: 572  (Read 413127 times)
Re: 572
« Reply #690 on: August 28, 2013, 10:25:56 AM »
so list the fees and key terms defined, dont DMV jungle gym it into a 4 month unknown process
Re: 572
« Reply #691 on: August 30, 2013, 01:38:39 AM »
big boy rear shaft welded up tonight
Re: 572
« Reply #692 on: September 01, 2013, 12:37:41 AM »
new rear shaft installed
rear 14 bolt hub seals replaced
front 60 torn down, inner axle seals installed
axle vents both ends installed
205 pulled on the bench and re sealed / re gasketed
oil cooler block off plated tapped and oil pressure sender hooked up for gage, idiot light sender installed
dash and leg padding installed
Re: 572
« Reply #693 on: September 01, 2013, 10:16:33 PM »
no longer leaking.  YESSSS
needs a radio, cup holders, tree bars, some other stuff
Re: 572
« Reply #694 on: September 04, 2013, 04:31:50 PM »
swapping coils tuning shocks tonight!
Re: 572
« Reply #695 on: September 04, 2013, 11:48:35 PM »
100/150 front less compression and less rebound
150/250 rear less compression not so much but still less rebound
no ride height change, fixed -1" preload on rear driver corner
Re: 572
« Reply #696 on: September 05, 2013, 02:08:27 PM »
Re: 572
« Reply #697 on: September 05, 2013, 03:19:30 PM »
http://www.offroaders.com/Search/ isn't a good image url
EDIT: assholes....
maybe a clickable is clickable
http://www.offroaders.com/tech/images/autogage4.jpg
Re: 572
« Reply #698 on: September 05, 2013, 03:25:14 PM »
works for me as i posted it hmm
Re: 572
« Reply #699 on: September 05, 2013, 03:28:06 PM »
me dos
Re: 572
« Reply #700 on: September 05, 2013, 03:30:32 PM »
lost the instructions for the tac.  was nice of them to put huge warning labels on the wires not to hook them up wrong and void warranty- you think they could have put a description for the 4 wires on those labels- no
Re: 572
« Reply #701 on: September 05, 2013, 03:35:10 PM »
weird, didn't work for me and right click to view in new tab brought me to their search page
Re: 572
« Reply #702 on: September 05, 2013, 04:02:25 PM »
same here.
Re: 572
« Reply #703 on: September 05, 2013, 11:35:44 PM »
shock tune much better but its got more to go.
i think the front needs more taken out of both, and the rear needs more taken out of just the rebound
ass end wants to go over the front when jumped just like the other car does.  not sure if its driving or not.  i dont think i was wimping it, and stayed on power
Re: 572
« Reply #704 on: September 06, 2013, 11:58:50 PM »
limit straps all 4 corners installed,
ready for more sky time
