Author Topic: 572  (Read 413128 times)
Re: 572
« Reply #495 on: July 30, 2013, 09:22:33 AM »
really that hard to assemble?
I got the set for the 6... haven’t opened the box yet
Re: 572
« Reply #496 on: July 30, 2013, 09:25:44 AM »
Mine came pre-assembled.  Just had to pull the unit bearing, clearance the knuckle, and insert the RCVs.
Re: 572
« Reply #497 on: July 30, 2013, 09:39:00 AM »
the 60 comes with a tool to remove them.  shaft assembly was easy.
install boot into knuckle, install shaft through knuckle boot.  no grinding on the solid nuckles needed.  large hammers and persuation to get the shaft into the boot, then allign with splines while large hammer to get CV to snap into boot.
never new the boots were hard plastic!
Re: 572
« Reply #498 on: July 30, 2013, 09:40:07 AM »
doing work!
Re: 572
« Reply #499 on: July 30, 2013, 09:41:52 AM »
never knew the boots were hard plastic!
The rest of the post before this makes much more sense after reading this haha
Looks frickin awesome, though. Cannot wait to see it in action
Re: 572
« Reply #500 on: July 30, 2013, 09:52:25 AM »
ya the boot is like same plastic as a Funnel, thats 5/16" thick
Re: 572
« Reply #501 on: July 30, 2013, 09:55:09 AM »
That boot is a pain!  I'd repressed memory of that part...  :P
Re: 572
« Reply #502 on: July 30, 2013, 10:44:11 AM »
RCV's or Superjoints? Which were more of a pain?
Re: 572
« Reply #503 on: July 30, 2013, 11:48:35 AM »
superjoints lol
Re: 572
« Reply #504 on: July 30, 2013, 01:52:35 PM »
taking friday to run around for metal, welding gas, hydro hoses and such
11 vacation days to burn left
JWOK
  • Full Member
Re: 572
« Reply #505 on: July 30, 2013, 05:16:49 PM »
Yeah they are a PITA. Then I had no idea how much grease to put in them. Eric and Brian thought more is better. My knuckles and wheels will never rust:)
Re: 572
« Reply #506 on: July 30, 2013, 05:41:10 PM »
Bah forgot to measure my car for hoses
Re: 572
« Reply #507 on: July 30, 2013, 05:59:07 PM »
you should of read the directions prior!
Re: 572
« Reply #508 on: July 31, 2013, 02:26:06 AM »
mine came greased, the dirrections did not say to add any i didnt  said to just put oil on the boot to slide in
JWOK
  • Full Member
Re: 572
« Reply #509 on: July 31, 2013, 10:08:59 AM »
They come with a tube of grease and a zerk in the end?
