Author Topic: 572  (Read 413131 times)
Re: 572
« Reply #480 on: June 24, 2013, 11:04:45 AM »
hard to tell these days- customer work is going to get in the way pretty soon.  race prep and trailer build also in the que.  I "think" i have everything i need other than a 14 bolt pinion and trans / steering lines.
Re: 572
« Reply #481 on: June 25, 2013, 04:14:37 PM »
Tire update.
Check received, tires palleted and sent.
Might have to go to terminal in buffalo to pick them up, Meh.
Re: 572
« Reply #482 on: June 25, 2013, 06:09:21 PM »
We're up there weekly if that works out and you need them picked.
Re: 572
« Reply #483 on: June 28, 2013, 01:08:48 AM »
one hugger wrapped.  disappointed in SS cable ties i got.
T case shifters fabbed and in.
Re: 572
« Reply #484 on: June 28, 2013, 10:09:22 AM »
tire pickup went well?
Re: 572
« Reply #485 on: June 28, 2013, 01:22:21 PM »
meh.  i have to bitch to him.  2 tire have bead damage that will probably be fine.  one tire looks like it was taken off with a sawsall.  one tire mint.  Awesome tread on all 4
Re: 572
« Reply #486 on: June 28, 2013, 07:11:00 PM »
Exhaust is looking good. I would have ended the exhaust with a simple 45* cut.
Re: 572
« Reply #487 on: June 28, 2013, 10:31:52 PM »
the end is a 4" cummins down pipe from turbo back,  its fun.
shafts all done.
Tcase shifters have bling handles i spun today
Re: 572
« Reply #489 on: July 27, 2013, 03:47:29 PM »
M4 all caught up so back at this thing.
Cell mounted
Battery mounted
Radiator pulled and chassis full welded around it.
Headers and exhaust wrapped and instaled with o2's
Re: 572
« Reply #490 on: July 28, 2013, 12:55:34 AM »
throttle cable at food done
trans to case alignment fixed
radiator hose adapters / mounts plumbed in
Re: 572
« Reply #491 on: July 28, 2013, 08:24:02 PM »
http://www.spike.com/episodes/sgqcbn/powerblock-xtreme-4x4-14-bolt-axle-101-low-dollar-wheeler-part-iii-season-3-ep-146
jump to the 10 min mark for front 14b oil issues
not sure if a flip D60 has same issues
« Last Edit: July 29, 2013, 11:57:32 AM by gif »
Re: 572
« Reply #492 on: July 29, 2013, 12:38:16 AM »
Two trans coolers mounted
maf and air cleaner mounted
Throttle at engine mounted
Re: 572
« Reply #493 on: July 30, 2013, 02:08:06 AM »
fuck dash tube work, im stumped.  on to finishing the rest of the car.
Rolled on the lift, front axle full welded and almost race prepped.
RCV's are no joke.  man tools needed and tight tolerances to assemble.
Re: 572
« Reply #494 on: July 30, 2013, 09:21:32 AM »
that looks awesome
