Author Topic: 572  (Read 412973 times)
Re: 572
« Reply #1650 on: February 02, 2019, 09:32:35 PM »
all back together and good minus a gallon of water and side tins.
5th 5.3 sounds good and tight first fire.
Re: 572
« Reply #1651 on: February 15, 2019, 08:53:07 PM »
lots of parts swapping and aggravation tonight.
confirmed bad IACV driver in PCM.
Re: 572
« Reply #1652 on: February 16, 2019, 08:58:21 PM »
That’s whack. Wonder how that fried.
I haven’t sold my spare pcms but you probably have spares too. Not unlocked/tuned.
Re: 572
« Reply #1653 on: February 17, 2019, 02:19:41 PM »
so some time spent with John this week
he burned me an "emissions pass" PCM  (any 99' PCM is free for him to burn with his batch liscence
i kinda wana build a street U4 now lol.  do home built, it would pass no issues. F NY
Re: 572
« Reply #1654 on: February 17, 2019, 02:20:27 PM »
also, unit ready to wheel.  all issues resolved and tins put back on.
Re: 572
« Reply #1655 on: August 18, 2019, 09:08:40 AM »
short side RCV gave up yesterday, boo.
new motor hot oil pressure is no good.
otherwise had some good laps on the short course and fun at the picnic
Re: 572
« Reply #1656 on: August 18, 2019, 12:42:48 PM »
Seems like it needs 40 $pline :(
Re: 572
« Reply #1657 on: September 27, 2019, 09:07:56 PM »
ready for trail status.
outer clip on short side decided to not do its job, shaft moved into spool, sheared last 1/4" of shaft after moving an  1" inward.
stupid failure.
Re: 572
« Reply #1658 on: September 27, 2019, 09:12:05 PM »
tried to change 2 shot rod ends on steering and gave up.  shit is tight.  spent more time than what it would have taken to Lathe out new tie rods.  F it, let it be there.
Re: 572
« Reply #1659 on: October 22, 2019, 08:21:20 PM »
this hawg took 27 gallons at the pump today.
Man i wish i could have plates on this.  so run to rip down the road to the neighbor fuel station dirty
Re: 572
« Reply #1660 on: August 11, 2020, 09:50:00 PM »
man had to go to page three to excavate this thread.
aired up some tires tonight and hawged a few laps around the property tonight at speed.
planned rear diff inspection and fix a slow leaking cover- found 3rd pinion bearing support in the 14 bolt smooshed over to the side.  all else looks good preload wise and gearset wise in the diff.
front has a broken diff cover bolt so that got pulled also, all looks well in the front.  will get an 1/8 turn on the king pin preload and new gear oil.  found some sweet cracks just about all the way around the truss near 3link loading.  will get a grind and weld and 2 small triangles added.
lube and fuel and good to go.
Re: 572
« Reply #1661 on: August 11, 2020, 10:23:25 PM »
snagging two 50$ 14 bolts tomorrow, because you can never have too many 14 bolts.
23$ bearing on amazon is 5 days away meh
Re: 572
« Reply #1662 on: August 12, 2020, 09:42:11 AM »
572 relieved from tractor duties now?   ;D
Re: 572
« Reply #1663 on: August 12, 2020, 10:16:02 AM »
multi use machine, but my cub has been doing great with tractor duties
Re: 572
« Reply #1664 on: August 13, 2020, 10:20:28 PM »
meh, got impatient and need this pile off my lift-  picked up two doner 14 bolts yesterday and harvested the bearing i needed that amazon says now will be delivered Monday instead of saturday.  should have just had one sent from dennys in buffalo for 10$ less and probably 22hr fedex.  meh
both diffs serviced. found broken hub bolts.
all heims on the car are loose wreck status.  added some ATF to steering.  need to scrounge though my broken RCV pile and see what spares i can make and what to send back.
time to un winterize the trailer....
