Author Topic: 572  (Read 413150 times)
Re: 572
« Reply #1110 on: December 04, 2014, 08:47:01 AM »
almost like a real company....
Re: 572
« Reply #1111 on: December 04, 2014, 09:15:25 AM »
ordering BFGs once i call to verify what i want in stock
anyone needs tires let me know.
Re: 572
« Reply #1112 on: December 08, 2014, 08:59:46 AM »
ripped into car last night with Matt
both diffs gutted, bunch of weight torched off!
Re: 572
« Reply #1113 on: December 08, 2014, 01:13:41 PM »
RCVs sent
RMA 112514JDO
Re: 572
« Reply #1114 on: December 08, 2014, 11:34:42 PM »
took my scale over to the shop
each of my tree sliders weigh 25 lbs
front bumper 15lbs
rear bumper 20 lbs
front 1/8" plate removed 8lbs
 :o
14bolt spool is 27 lbs-  might lathe off another 8lbs
14bolt oe clam and welded globe 33lbs
Re: 572
« Reply #1115 on: December 09, 2014, 09:29:58 AM »
have building some spare drive shafts in the back of my mind since even though i have been through a lot of iterations of improvement- they still seem to be one my my common failures.
mid shaft in the car is a good spare, but it has a slugged section, with the failure of plug weld designed removed.  i have 3/8 wall DOM to replace it but having a hard time coming up with a way to adapt while maintaining strength.  have a few 60 pinions laying around, 1350 yokes are 50$ each
im tempted to go back to original 2" 120 wall tube to 14bolt yokes, with a slug of 7075 inside of it to keep bending down
Re: 572
« Reply #1116 on: December 10, 2014, 09:55:06 AM »
ordered some fresh KRTs
started turning down a yukon spool last night- currently at 12lb lighter than OE clam, have a bit more to go.  all carbides are not a like!  turning twislers!
Re: 572
« Reply #1117 on: December 12, 2014, 01:01:00 PM »
14bolt weight reductions in
14bolt OE clam  33lbs
yukon spool 27lbs
M4 shaved yukon spool 18lbs
15 lbs lost!
Fresh sticky KRTs delivered this morning
Re: 572
« Reply #1118 on: December 12, 2014, 06:39:31 PM »
i love the smell of new tires in the morning...
Re: 572
« Reply #1119 on: December 12, 2014, 06:57:33 PM »
im more a sucker after they are mounted on the new KMC's i have sitting still in boxes....
Re: 572
« Reply #1120 on: December 12, 2014, 07:31:35 PM »
have you been deleting pics off this build thread?
Re: 572
« Reply #1121 on: December 12, 2014, 07:48:32 PM »
the forum gets purged from time to time of old attachments
Re: 572
« Reply #1122 on: December 13, 2014, 08:04:20 AM »
Those look more like HEAVY truck tires than sticky desert tires
Re: 572
« Reply #1123 on: December 13, 2014, 09:52:52 PM »
14 bolt gear set back in
front solid 60 cover has a crack in it
7075 tie rods machined
winch pulled
radiator mount trimmed up
battery mount trimmed up
mud chipped and vacuumed out of sub
Re: 572
« Reply #1124 on: December 14, 2014, 07:45:45 AM »
Better find an extra 4 - 5 lbs to shave off somewhere to compensate for the new radio.
Wow these are heavy.
I suppose you could pull it out for weigh in
