Author Topic: 572  (Read 413435 times)
Re: 572
« Reply #1065 on: September 04, 2014, 12:30:04 PM »
great, ups says the rest from enco is on a truck out for delivery.  that was fast!
i am a pro at links now- still takes a long time lol
Re: 572
« Reply #1066 on: September 05, 2014, 01:52:29 PM »
KY prep Progress
Re: 572
« Reply #1067 on: September 05, 2014, 02:01:37 PM »
poor car, it was so bad ass looking till you put on what looks like forrest gump leg braces
Re: 572
« Reply #1068 on: September 05, 2014, 02:17:56 PM »
whahuh?
Re: 572
« Reply #1069 on: September 05, 2014, 05:42:40 PM »
that shiny contraption of nascar parts
Re: 572
« Reply #1070 on: September 05, 2014, 11:55:11 PM »
thanks for the help tonight guys
new aluminum top locked in
Re: 572
« Reply #1071 on: September 08, 2014, 02:01:46 PM »
u4 needs
breakdown device  Two battery-operated red-light flashing beacons or two red reflective
devices must be carried in the vehicle as breakdown safety devices. Reflective
devices must be at least 12” high and 12” long and be free standing (similar
to trucker’s breakdown triangles
check first aid kit
Front / side/ rear numbers
weight 4400lbs
Gussets must be installed at all major intersections, including diagonal and
rear down braces, where single weld fractures can affect occupants’ safety.
Gussets constructed of 3” x 3” x .125" flat plate or split, formed and
welded corner-tubing, or tubing-gussets made of the same material and
thickness as the roll cage may be used.
Each vehicle shall have a means of applying continuous brake pressure while
vehicle is parked with occupant(s) outside the vehicle. Hydraulic “line-locks”
or mechanical “emergency brakes” are permitted.
There must be a substantial cross member and firewall between the fuel
tank and the occupants
Internal baffling is mandatory in all
fuel cells. Foam is an acceptable form of internal baffling
Fuel isolation valves that facilitate isolation of the fuel tank from the fuel supply line, fuel return line,
and fuel vent line are required. Ball valves, or a combination of ball valve
and one-way check valve, located at the supply, return, and vent line are
acceptable.
Fuel tank must be filled from, and vented to, the outside of the
occupants' compartment.
All fuel fillers attached to the frame or a body panel must be connected to
the tank using flexible couplers. Boot or splashguard must direct fuel spillage to outside of vehicle and away
from occupants’ compartment, engine, and exhaust.  A fuel filler roll over or check valve must be incorporated in the cell.
Fuel vent lines must have a rollover check valve incorporated at the fuel
cell, and must vent outside of occupants’ compartment, and be directed
away from the engine and exhaust system.
6.2.14.3.7 Fuel vent line must use one of the following routings:
6.2.14.3.7.1 Fuel vent line must extend to the highest point of the roll cage
nearest the fuel cell, across the width of the vehicle, and down to below the
belly pan of the vehicle or 3” below the fuel cell, whichever is lower.
6.2.14.3.7.2 Fuel vent line must loop above the fuel cell to a point that is 4” above
the top of the fuel cell. From there it shall be wrapped one full loop around
the outside of the fuel cell near the top of the fuel cell and then be routed
down to a point 3” below the lowest point of the fuel cell.
Fueling mat
Re: 572
« Reply #1072 on: September 08, 2014, 04:54:59 PM »
Matt at Dynomax getting me into 2014 Contingency program
just in case i win something this weekend :)
Re: 572
« Reply #1073 on: September 09, 2014, 09:15:46 AM »
mounted 3 more tires on new KMC's
all three wheels short 2 washers in hardware kit
one wheel is missing 1/2 the machine work for the inner air lock fill
one of the rock rings is 1/8" thicker than the other two
 :o
Re: 572
« Reply #1074 on: September 09, 2014, 09:56:59 AM »
rush job? Friday job?
oi.
glad some things showed up though. Good luck, sorry I've not been over to help out.
Re: 572
« Reply #1075 on: September 09, 2014, 10:57:46 AM »
huh
mounted grooved bald tires.  we dont have new tires.
i have had the new wheels for weeks
Re: 572
« Reply #1076 on: September 09, 2014, 11:09:54 AM »
wondering if the wheels were a rush job or just built last thing on a friday
Re: 572
« Reply #1077 on: September 09, 2014, 11:40:19 AM »
o, gotcha
no clue
Re: 572
« Reply #1078 on: September 15, 2014, 11:04:04 AM »
we got a police escort from the track to the fair grounds.
572 is tight and drives straight at 55mph on pavement now for some reason lol
dove the crap out of this car
needs more motor and suspention.
flys fine.  takes casing / lawn darting doubles like a chap.  only almost hurt my self once.
air cleaner was packed 2nd race.  boo.  changed out and ran hard LCQ
no tire issues.  trans likes to be left in 3rd best.
both cars passed hammer teck and chassis are banded
Re: 572
« Reply #1079 on: September 15, 2014, 11:09:31 AM »
Stellar
Very cool on the police escort too :)
