Author Topic: Used Up  (Read 40663 times)
Used Up
« Reply #75 on: September 24, 2012, 06:50:22 PM »
Oh, I can see the wear pattern from my photos. Front is shallow rear is deep IIRC. Left that on my work computer.
Used Up
« Reply #76 on: September 24, 2012, 07:11:34 PM »
Gears alone about $405+ship from Randy's for the cheap US Gear stuff. Same price 5.13 or 5.38.
Plenty of effort but that's pretty cheap to ignore. Fuck I wish I had a shop on site. Would be so much more productive. (read: have so much more shit and still get nothing done because I'm a lazy puke)
Re: Used Up
« Reply #77 on: September 24, 2012, 11:23:35 PM »
that sounds spendy for gears
spenser found a pirate guy that was better that PORC with install kits.  you probably dont need install kits, and i still have a ton of 60 shims and shat
Re: Used Up
« Reply #78 on: September 24, 2012, 11:40:39 PM »
yeah, I should just need the gears. I saved all the shims from the old kits. As long as the bearings are OK with going on and off without grenading it should be okay. Would be nice if I could find the shims for the 10.25 solid spacer that I missed last time too.
 I figured Randy's list prices would be on the high side of available options; if I can do it for even less than that it's even dumber not to do it.
Re: Used Up
« Reply #79 on: September 25, 2012, 06:50:49 AM »
baseline 4x4 tonyfeichter@baseline4x4.com
USA Standard Ring & Pinion gear set for Dana 60 Reverse rotation in a 5.38 ratio (thin cut)    $186.33
USA Standard Master Overhaul kit Dana 60 front, non-disconnect   $114.05
USA Standard Ring & Pinion gear set for 10.5" GM 14 bolt truck in a 5.38 ratio   $172.80
USA Standard Master Overhaul kit for the GM 10.5"  14T differential, '89-'98   $140.16
wayne hartwig
$150 - ZG D60R-513R-T USA Standard (HP60 5.13 thick cut gears)
$175 - YK D60-F (Dana 60 Master Install)
$140 - ZG GM14T-513T USA Standard (14b 5.13 gears)
$170 - YK GM14T-A (14b Master Install)
http://www.pirate4x4.com/forum/axles-tires-wheels/1042150-ring-pinion-sets-sale-now.html
525 shipped for USA Standard gears and install kits. 5.38s for HP60 and 14B
Re: Used Up
« Reply #80 on: September 26, 2012, 12:37:21 PM »
sell the wedge for 2000$, scrap 2 cars for 500$
$1500 in full hydro / knuckles / arms
$600 gears
$400 tube
Leave or swap to used softer coils, buggy leaf whats in the rear.
No change from use now other than it will need a bigger tarp when it rains.
disregard women, acquire currency, add coilovers, and build to pass tech.
Re: Used Up
« Reply #81 on: September 26, 2012, 12:52:14 PM »
you got it. now do it....
Used Up
« Reply #82 on: September 26, 2012, 05:37:03 PM »
Throw gear oil back in things, wheel mostly local for a bit and not waste a Rausch trip on stripped gears. Reseal steering box and weld frame cracks.
Finish Nissan and Jetta. Sell  2 of Nissan/ Eagle/ Jetta. Get garage back.
Then work on wheeler, or white eagle.
Probably gears and plate front diff first. Then tube or something?
carchameleon
Re: Used Up
« Reply #83 on: September 26, 2012, 08:48:57 PM »
i could use a tdi for my new commute..
Re: Used Up
« Reply #84 on: September 26, 2012, 08:51:01 PM »
Well fill us in on the commute part
Used Up
« Reply #85 on: September 27, 2012, 09:20:09 AM »
1500 it's yours as is delivered. Have signed title and *maybe* a good battery too.
Offer expires when I finish the Nissan and start on it.
Re: Used Up
« Reply #86 on: September 27, 2012, 10:06:06 AM »
i hope you didnt pay 1500$ for that thing haaha
Used Up
« Reply #87 on: September 27, 2012, 10:20:29 AM »
Whats the deal with that car?  Forgot you had it hahaha.
Used Up
« Reply #88 on: September 27, 2012, 10:58:32 AM »
No, I didn't. That's what he was asking.
Needs a wheel straightened, power steering line replaced, intake cleaned, charge piping and some other frontend body parts reassembled, outside mirrors and radio antenna broken. due for a timing belt.
Could be a rusty driver.
Re: Used Up
« Reply #89 on: April 08, 2013, 03:52:29 PM »
I wonder if I should drop the cases & winch out of this, and have a claw grab it off the axles along with dumpbus...
it runs and drives, but I really question the true status of engine and trans right now. didn't notice the chipped gears whatsoever yesterday.
structural issues could be patched together again; steering leak has never been identified. things are VERY crowded up there, but maybe a good brake clean washdown and fluid fill could confirm the source.
