Author Topic: Used Up  (Read 40704 times)
Re: Used Up
« Reply #60 on: September 24, 2012, 08:56:57 AM »
Run it.
Worse case, you break more gears and get towed back to the trailer.  :-\
Re: Used Up
« Reply #61 on: September 24, 2012, 09:21:22 AM »
or throw 500$ at it and regear it again?  maintence item.  im amazed the buggy doesnt have missing teeth.
Re: Used Up
« Reply #62 on: September 24, 2012, 11:11:47 AM »
Musta done a better job setting up 571's than mine. I'm really curious what my patterns look like.
Decision is essentially regear now when it's PM, or wait till I strip out both R&Ps in the middle of Pensyltukian and then light it on fire...
broke the windshield the second time up Dragon's Back (that's it's name, right?).
Re: Used Up
« Reply #63 on: September 24, 2012, 11:20:53 AM »
This poor truck has just gone to shit in the last 3 years.
Re: Used Up
« Reply #64 on: September 24, 2012, 11:23:12 AM »
hmmm, that would have nothing to do with ridding in 571 for the last 3 years.....
Re: Used Up
« Reply #65 on: September 24, 2012, 12:36:49 PM »
I think it might have more to do with zero PM since it started getting trailered aside from hammering on things to make body panels fit again
Re: Used Up
« Reply #66 on: September 24, 2012, 02:08:35 PM »
What the hell is PM?
Re: Used Up
« Reply #67 on: September 24, 2012, 02:23:33 PM »
preventative maintenance duh!
Re: Used Up
« Reply #68 on: September 24, 2012, 03:18:47 PM »
that works on sooooo many levels from you
Re: Used Up
« Reply #69 on: September 24, 2012, 03:49:07 PM »
Used Up
« Reply #70 on: September 24, 2012, 04:19:21 PM »
ROFL
Is that legit or is that place The Onion of racing news?
Re: Used Up
« Reply #71 on: September 24, 2012, 04:26:51 PM »
Its, "The news before it happens"
Re: Used Up
« Reply #72 on: September 24, 2012, 04:28:53 PM »
A pic for you
Re: Used Up
« Reply #73 on: September 24, 2012, 05:04:26 PM »
packages 1-5 of 5, special bicycle courier delivery.
Used Up
« Reply #74 on: September 24, 2012, 06:49:09 PM »
Bottom of the front diff is ~0.150" thick. Thats a hundred thou away from "fine"
I got depressed looking at it so I came inside.
I can probably do a halfway OK plating job with the housing installed. Grinding the face flush with the guts installed might be another matter though.
Jeff I make fun of your diff skids but maybe you've got the right idea. Replacing that steel is way easier the replacing what's behind them.
