Author Topic: Used Up  (Read 40660 times)
Re: Used Up
« Reply #30 on: August 23, 2012, 11:57:49 AM »
Smike is a baller shot caller!!
Re: Used Up
« Reply #31 on: August 23, 2012, 12:05:28 PM »
i call it as i see.
Dakota is a well used tool, its amazing what its been though, and what its capable of.
That being said, it has been long neglected for serous change or replacement if i owned it haha
Re: Used Up
« Reply #32 on: August 23, 2012, 12:07:40 PM »
are you making mike an offer,pretty sure he'll take 571 as a trade
Re: Used Up
« Reply #33 on: August 23, 2012, 12:10:18 PM »
i see no offers made in those statements
Re: Used Up
« Reply #34 on: August 23, 2012, 03:05:15 PM »
long neglected because it needs 2 grand in shit to still not be raceable.
air shocks on it would fix most comfort issues but cause lots of changes at the same time. the only small bite needed is hydro steering and that's pretty much my lowest priority complaint.
Re: Used Up
« Reply #35 on: August 23, 2012, 04:59:45 PM »
Who cares it still runs and is free I would just keep running that puppy
Re: Used Up
« Reply #36 on: August 23, 2012, 05:47:05 PM »
i still remember the day the tail gate slammed into the hitch when mike was pissed about hitting a tree a little on the one bed side.  it was awesome.
Re: Used Up
« Reply #37 on: August 27, 2012, 04:31:38 PM »
I'm amused that 14 months ago I boogered this thing back together from 2 pieces.
Used Up
« Reply #38 on: September 17, 2012, 12:20:33 AM »
Need to change all fluids, pull codes, new battery and I bet a new front O2 sensor.
Used Up
« Reply #39 on: September 17, 2012, 07:52:44 PM »
Used up. Things are falling apart under there!
Code is TPS related, that makes sense for poor running at low throttle and idle stalling.
Trans is draining. No chunks in the pan, but more than nothing. Magnet was not installed.
Short shopping list. Haven't decided if I'll spend the money to fill, run & drain the trans once. I probably Gould since it still seems serviceable.
Temp sender and magnet will be reinstalled.
Re: Used Up
« Reply #40 on: September 17, 2012, 10:11:54 PM »
bunch of frame cracks on both sides should get some attention also
Re: Used Up
« Reply #41 on: September 18, 2012, 12:06:08 PM »
there are a couple of those.
I took some pics of the underside yesterday and logged the damage :)
https://www.facebook.com/media/set/?set=a.820911354938.2178851.3703946&type=1&l=57c77e986b
Re: Used Up
« Reply #42 on: September 18, 2012, 12:19:35 PM »
Is it time for a moment of silence?
Re: Used Up
« Reply #43 on: September 18, 2012, 12:52:17 PM »
it deserves what josh did to my poor scrambler
Re: Used Up
« Reply #44 on: September 18, 2012, 01:28:27 PM »
Josh was intending to take some good, salable parts off that Scrambler. I don't have that option.
