Author Topic: Used Up  (Read 40744 times)
awl4928
Re: Used Up
« Reply #105 on: June 03, 2013, 04:57:53 PM »
I thought she was only 3 wheel after eriks?
Re: Used Up
« Reply #106 on: June 03, 2013, 05:00:30 PM »
locker issues. probably fluid related, has fresh oil in it now.
Front [...] Locker looks good though; I'll take a closer look after it drains and drools off and I don't need to waste 14 cans of brake cleaner. The gear oil that came out was like custard. 200w I'd bet. Probably the issue.
Re: Used Up
« Reply #107 on: June 03, 2013, 05:15:47 PM »
900$ shipped for 2psc rams, clevis kits, extra clamps and matts column
we have the technology at M4
Re: Used Up
« Reply #108 on: June 03, 2013, 05:45:24 PM »
I could write a list of what it needs but it's long. hence the thread title :)
the diffs need plating ,the frame needs welding, the cases need seals, it needs coilovers and links and heims and fresh gearsets and things I'm not thinking of and it's still not caged, has no seats and no harnesses.
....and the Eagle rides 43x as nice. at street pressure. with bad shocks. that's saying something
Re: Used Up
« Reply #109 on: June 13, 2013, 12:58:55 PM »
i am ording multiple gear sets, you want some?
Re: Used Up
« Reply #110 on: June 13, 2013, 01:02:07 PM »
eh, i guess my chosen vender only has 4.56 listed for your axles, 170$ for the standard low 10.25, 155$ for the reverse thick 60
Used Up
« Reply #111 on: June 13, 2013, 01:13:22 PM »
I'll pass on 4.56. 5.13 would probably be close enough, but 4.56 is just too shallow. Thx
Re: Used Up
« Reply #112 on: June 13, 2013, 01:53:39 PM »
seems a thick standard rotation 5.38 is not easy to find
Re: Used Up
« Reply #113 on: June 13, 2013, 02:10:19 PM »
reverse?
they are out there.
try wayne hartwig.
or the pirate vender i linked in the chromo shafts thread in the for sale section
also ccor (or whatever that company is)
Re: Used Up
« Reply #114 on: August 15, 2013, 08:30:57 PM »
Battery is 0% alive. Again.
Even when mostly dry, the power steering leak source is indefinite. Fluid just appears. Either shaft seal on the pump, can-to-pump gasket, or front cap seal on the box. I should probably pull the pump; I don't think the box actually saw any pressure so I see that as least likely. System leaked with engine running and maybe a pint added.
Found how the outer frame welds crack so fast at the box mount sleeves: the inner half of the boxed rail is separated from the frame at the bottom. Well-hidden behind old stock front crossmember pieces.
Not an encouraging first look.
Re: Used Up
« Reply #115 on: August 15, 2013, 11:19:58 PM »
New battery + full hydro?
Re: Used Up
« Reply #116 on: August 16, 2013, 12:27:18 PM »
the bandaid list is long and involved. I wanna wheel, buuuuut... you know?
I suppose pulling the front axle and redoing the front links/ link mounts, doing full hydro, plating the bottom of the housing, getting a battery and steering orbital, etc isn't wasted money - but then I put it back in a truck that still rides like shit (front coil springs ~$200 wasted money), needs motor mount and tcase mount work (time, though, dirt, welding), has no exhaust left ($40 wasted on another flex pipe & clamps to do it easy & wrong), and will eat rear driveshafts without yet a lil more work (pull leaves, add shims, rebuild shackles with bushings).
So, a grand and change plus gear sets.
fuckit, if I had a place to work that'd already be done. I need to finish that TDI and get Dump Bus parts out of the garage so I can curse how much too small it is all over again.
Longer term I'm thinking of tube based off the dakota grille & hood. truck style lines with a short cab. probably back to a married case aiming for a 110" wb and keep the 42s for now. carry it on the back of High Miler for local trips with the rear tires on a platform behind/below the bed.
motor sounds GREAT when it has full voltage to it. no stumbling, no tripping over itself returning to idle. I have at least one spare trans. 727 or 46/47/48RE will all mate if the 44REs don't live and I have a manual trans 360 PCM already sitting to do a 727 setup. 318/360 are dime a dozen in stock form even if not as cheap to mod as LS. that's a couple grand saved in using what I've got (ignoring $800 van options). leave a few inches all around and if the chassis is good enough to deserve it, a HEMI or LS could go in its place later.
Re: Used Up
« Reply #117 on: August 16, 2013, 01:11:22 PM »
i think you need a little less race prep mind set and a little more bushmechicry to get this hawg rolling for another season as is.
i see battery and steering pump, and some 1/4" plate welded on, air up the tires and go wheeling with a big cooler strapped in the back.
Re: Used Up
« Reply #118 on: August 18, 2013, 04:48:08 PM »
Gonna try and put a pump on this and one of the hopefully good batteries from my bench. Maybe make Rausch with it this weekend?
Re: Used Up
« Reply #119 on: August 18, 2013, 11:36:12 PM »
i have 3 good batteries on the shop floor, a hydro ram and 2 tie rods you are welcome too.  probably on your own for hoses as my spares fit both cars.
can the box be tapped?
