Author Topic: Tire Vulcanizing setup  (Read 36141 times)
« on: January 17, 2025, 07:17:52 PM »
Ordered heat press with dies
rubber gum sheeting
nylon thread and leather stitch all tool
buffing wheels and stitcher (lost box of my tire repair supplies?)
non heat set glue
heat set glue
cleaner
various 10" and 7" bias 6ply patches for inner added strength
will report back after some test trials
Re: Tire Vulcanizing setup
« Reply #1 on: January 17, 2025, 09:33:19 PM »
I think I have the buffer wheel. I wonder what shelf life on some of that stuff is
« Reply #2 on: January 18, 2025, 08:43:18 AM »
i recal you giving me the box back at some point, but that may have been 5 years ago lol  and it could have been borrowed again no worries
the gum cushion rubber i ordered it says to store in freezer to last not sure about glue, but you make your own glue also with this rubber and ethonal free gas easy i guess
« Reply #3 on: February 19, 2025, 05:00:40 PM »
started on a test tire today
cushon rubber soaking in e0 to make glue needed
« Last Edit: February 19, 2025, 05:05:32 PM by M4wdFab »
« Reply #4 on: February 20, 2025, 01:25:29 PM »
still waiting for my tire glue to form up.
strips of cushion rubber soaking in non ethonal gas.  youtube says 2-3 days
« Reply #5 on: February 22, 2025, 03:12:34 PM »
4 days and about cushion gum rubber not liquefying to black glue/goo like youtube said it would in 48hrs.  tried more mixing and added more fresh E0 and left top of can open this this time.
« Reply #6 on: February 23, 2025, 09:17:02 PM »
first attempt at heat press usage.  30% of the result i was shooting for.  doesnt really appear to have "melted" the rubber together after 90 minutes.
added some more rubber and glue to one of the edges that i missed and reset for 180 minutes (full dial)
no temp control just time and "auto"
« Reply #7 on: February 24, 2025, 03:57:05 PM »
ok made progress on this today with 3 more repairs.  Im more like 80% of what i want and getting the hang of it and i think its def possible now to achieve good results.
finished my test tire and then did chris's 37" red today in a tricky spot and it turned out pretty good.  one of my bald KOH 42s is cooking right now on one of its sidewall cosmetic blemishes.
« Reply #8 on: February 24, 2025, 03:58:55 PM »
Chris's red i made a 3/16" thick aluminum spacer plate that contoured to the heating element shoe around the BFG side lug, worked great.  just need to trim /finish it up a bit to make it cosmetically better but rubber stuck good.  Outside material only on that one.
« Reply #9 on: February 24, 2025, 04:00:55 PM »
this is the first test tire, i mounted up, 40 psi and no bubbles.  this one got cords stitched, and rubber both sides.  cooked it twice since it really didn't take right and needed to re position shoe over a bit- looks a little funky but structurally sound.
« Reply #10 on: February 24, 2025, 05:53:22 PM »
cool!
« Reply #11 on: February 24, 2025, 06:44:24 PM »
first screw up logged.  i think i was jumping the gun and trying to pull the shoes when it was still too hot to try and set up another one.
bah.  cleaned up, re prepped and gummed,glued and reset to cook
im thinking id like to buy a second heat press.  to get two rolling at the same time after getting the shop setup for it
« Reply #12 on: February 25, 2025, 05:54:41 PM »
more continued succes today, getting the hang of this thing and learning what not to do
did my first "tread" repair.  had about a 3/8" size hole stuffed with plugs.  first time i used a 3" patch in addition to the rubber i added on the hole and outside with another aluminum tread piece i made
mounted and bubble checked all good.  tire has some other bead issues so it will get bead sealer or slime eventually.  this is chris's spare 37 red now.
