Author Topic: new buggy build  (Read 160236 times)
Re: new buggy build
« Reply #16 on: November 13, 2023, 05:05:42 PM »
welding the "diff" in the auto is more of a project than i was hoping.... F me
https://www.youtube.com/watch?v=-zM2YdBBGCs
That looks awful.
Re: new buggy build
« Reply #17 on: November 14, 2023, 01:51:28 PM »
wired and plumbed on the K member this morning and strapped to the RAM to run out to Johns and pull VATS from the computer this afternoon.  fingers crossed its happy with no Fuel pressure control module connected and a corvette 58psi filter reg.
runs and stalls as it should with VATS enabled and good OBD communication right now.
Re: new buggy build
« Reply #18 on: November 14, 2023, 03:53:34 PM »
is VATS the gm immobilizer?
yes it is. Vehicle Anti Theft System.
sounds like progress, but Ryan is right. that looks pretty damn awful.
Re: new buggy build
« Reply #19 on: November 14, 2023, 05:22:14 PM »
sucess with john, all well with my wiring mods.  enabled power enrichment @2500rpm so should be boost ready anytime
SD axle weighed in at 558lbs
ecotec, trans, kmember, battery, 2.5gal tank, ect 630 lbs  lol
Re: new buggy build
« Reply #20 on: November 15, 2023, 05:10:40 PM »
harness fully trimmed down, all excess wires pulled, re loomed, cleaned up to 3 wires, obd, gas petal.
Re: new buggy build
« Reply #21 on: November 15, 2023, 06:04:33 PM »
If the case cracked with an open diff, how well will it do "locked"?
Re: new buggy build
« Reply #22 on: November 15, 2023, 09:11:21 PM »
unknown.  lots of derby guys use these things so should be fine.
still working out a few of the design ideas
Re: new buggy build
« Reply #23 on: November 15, 2023, 10:18:24 PM »
Cool!  I love the concept of symmetrical suspension setup/links.
Re: new buggy build
« Reply #24 on: November 16, 2023, 06:17:08 PM »
That looks awful.
took me 4 hours including welding the diff and letting it cool for a half hour
wasn't too bad, transmissions are fun.  i would feel fully confident in rebuilding one now.
only fail was snapping a starter motor termanal (after heat and PB) and having to torch out speed sensor (rusted brittle seized plastic).
Re: new buggy build
« Reply #25 on: November 16, 2023, 10:33:40 PM »
just found this guys old build thread, using same exact transaxle.
pirate adds are painful but he goes into detail about fighting transaxle c clips.  he even cut a window into the side of the transmission housing lol.
I was going to ignore this and say it would be fine, but i guess not now.  going back to thinking about 4bolt bearing retaining flange and something to hang a rotors before a driveline flange to delete corner brakes also.
Re: new buggy build
« Reply #27 on: November 16, 2023, 11:19:58 PM »
going to try D30 unit bearings, stub shaft, rotor and see how packaging looks.
Re: new buggy build
« Reply #28 on: November 17, 2023, 10:16:30 AM »
use Brave browser. It blocks ads. Also blocks ads in youtube videos.
Re: new buggy build
« Reply #29 on: November 17, 2023, 02:15:08 PM »
realized i have lots of ford 8.8 pinions, flanges, yokes, and 1350 super duty shafts.  should be able to size a 4 bolt bearing flange and adapt to transaxle cup to retain, and support, 1350 drive shaft CVs will be nice also.
think i have ditched the pinion brake idea... dont these things usually get water/steel shot in the tires anyway lol, i guess that weight will help on the corners
stared at a TC pump today, decided not worth 150$ in my time to not order the CBR bracket on ebay that bolts on.
