Author Topic: M4wdriveway Yota Exo  (Read 139928 times)
Re: M4wdriveway Yota Exo
« Reply #165 on: April 24, 2012, 09:00:51 AM »
Lol it wouldn't have taken much. It was glowing good
« Reply #166 on: April 24, 2012, 10:43:21 AM »
bleeding instructions says full lock turns bad
http://www.howeperformance.com/pdfs/bleed-instr.pdf
The pump restrictor actually unscrews from the pump, drill, screw back in.  Damn that would of been simple while it was apart :o
Quote
Once out, turn the restrictor upside down on a hard surface and tap a couple of times. A bushing will fall out. Now drill the orifice in the restrictor out to 13/64. After drilled out, put the bushing back in and bolt it all back together
Res extension using 3.5" exhaust pipe
Cheap res http://www.speedwaymotors.com/Speedway-Vertical-Steering-Reservoir-Tanks,2062.html
The motivation to work is not schrong today  :o
« Reply #167 on: April 24, 2012, 11:10:02 AM »
Hmm, so that alternator is actually a 3-wire correct?  We just hooked it up as 1-wire.  So I could hook my stock remote sensing wire to it for optimum performance, which I obviously need ;D
http://bob_skelly.home.comcast.net/~bob_skelly/alternator_conversion/wiring_alternator1.html
« Reply #168 on: April 24, 2012, 11:10:30 AM »
ok i really need to work now
« Reply #169 on: April 24, 2012, 12:04:05 PM »
the alternator works i would not complain lol
« Reply #170 on: April 24, 2012, 12:27:01 PM »
I was not complaining n-bomb
« Reply #171 on: April 30, 2012, 01:30:28 PM »
What a pile!
« Reply #172 on: April 30, 2012, 01:35:18 PM »
ridding dirty 86.25% of the weekend!
no good!
« Reply #173 on: April 30, 2012, 02:36:47 PM »
Easy fix.  ???
« Reply #174 on: April 30, 2012, 06:57:56 PM »
Not too easy or it'd be fixed!
« Reply #175 on: April 30, 2012, 07:10:12 PM »
Sounds like user error ;D
« Reply #176 on: May 03, 2012, 09:57:33 AM »
looked through the FSM last night, soooooo many things it could be :-\
« Reply #177 on: May 03, 2012, 09:58:10 AM »
hydro works great tho 8)
« Reply #178 on: May 03, 2012, 10:00:50 AM »
m4 does good work!
« Reply #179 on: May 05, 2012, 09:44:41 PM »
This thing ran just fine for over an hour today wtf
