Author Topic: 1947 KB3 2016 GMC 3500 chassis  (Read 72660 times)
« on: January 31, 2023, 12:43:33 PM »
Picked up a 47 KB3 yesterday
have a 2016 GMC 3500 dually chassis for it
have steel and lumber for flat bed
need to unload, organize and see what little bits i need
needs glass
front hood emblem
was a driver 3 years ago
all torn down for rebuild
frame and axles look new lots of good IH parts to possibel flip
Re: 1947 KB3 2016 GMC 3500 chassis
« Reply #1 on: February 01, 2023, 02:32:40 AM »
looks like a lot of other neat classics in that barn.
Truck is in awesome condition
« Reply #2 on: February 01, 2023, 11:29:08 AM »
bunch of weird stuff in that barn, he owned them all.  some odd balls and some high end stuff.
truck is pretty solid, was hoping it was in better shape for what i over paid for.  bottom of inside of doors gone, 2 spots in side the cab gone, and bunch of body filler cracking spots on it- meh.  Ill probably end up having to paint fix some areas and paint it.
found the missing emblem on ebay for 100$ actually (usually they are 2-$350) and need to track down the glass marker lenses.  only found one broken one in the parts crate it came with.  did find the missing head light bezel and windshield hinge out parts.
listed axles and frame for sale.
« Reply #3 on: February 04, 2023, 05:51:03 PM »
cab, front clip, hood mated
realized today one the inner fenders is missing, that sucks.  didn't see that.
other parts missing: front bumper and front bumper deck piece.  i have a chevy bumper, and can make that other piece i guess.
found missing hood emblem and glass marker lenses on ebay for not too bad.
all glass, seals, fender seals available
much more body work needed than i hopped, bah.  probably 10 spots outside and 2 spots inside require metal / fill
« Reply #4 on: February 05, 2023, 07:43:14 PM »
2016 chassis rolled under
some prep and then start lower/cut/lower/cut.  have too look back at my last KS5/2014 build to remind me a few things i did but looks pretty straight forward.
« Reply #5 on: February 10, 2023, 07:45:09 PM »
cab fully mounted and bunch of body work done to top side
started on steering hookup
« Reply #6 on: February 11, 2023, 10:25:25 PM »
also noted i searched my entire shop for no less than 45 min for and assumed missing first section of the steering shaft for this 2016 rig i swore that i never removed from the chassis, and then realized i was thinking of one of the escalade chassis still had mounted, and all parts needed were sitting the bench.  bah!
continuing on tomorrow.
« Reply #7 on: February 16, 2023, 02:11:07 PM »
john got me some pinouts off Alldata
have trans pinouts for canbus hookups /wakeup needed
might be able to fire it today or tomorrow.
ordered full glass, seals, headliner, radiator
« Reply #8 on: February 16, 2023, 06:11:54 PM »
bah first try no start
starter motor is intermittent too but got it so i confirmed it doesn't pop with brake clean
found a 50 page build thread guy did same swap in a c10.  also he has an LS wiring swap thread.
didnt document what he did, bah.
i had john delete vats.
wondering if there is more that needs to be done
« Reply #9 on: February 16, 2023, 07:14:54 PM »
it seems e78s are hated in the LS comunity lol.
did find one tit bit to try after 2 hours searching!
Quote
Just a heads up, if you're running the e78 ecm make sure either your "starter enable relay control" wire from the ecm is either hooked to a ground or make sure your starter diagnostics are turned off in your tune. If not, your injectors will not pulse no matter what you do.
Quote
The e78 make sure you turn off the starter diagnostic along with the normal VATS / 02 etc. the starter diagnostic will cause no fuel via the injectors. soon as I disabled that she fired right up.
« Reply #10 on: February 16, 2023, 07:45:46 PM »
(C6) C6
(C6) 0.5
(C6) YE/BK
(C6) 625
(C6) StarterEnable RelayControl
« Reply #11 on: February 16, 2023, 08:12:30 PM »
thus far"
pin9   6l90 trans  to +12 wake up
pin10 6l90 trans  to tan/bk PCM Bl/Bl pin 29 can bus +
pin11 6l90 trans  to tab     PCM Bl/Bl pin 43 can bus -
connector X2
all pinks to ign 12v
3 red/w to constant power
large purple starter crank
« Reply #12 on: February 16, 2023, 09:49:16 PM »
fuel gage specs
Resistance Ohms Empty:   250 Ohms
Resistance Ohms Full:   40 Ohms
« Last Edit: February 17, 2023, 07:57:51 AM by gif »
« Reply #14 on: February 17, 2023, 10:38:20 AM »
holy smokes, 1,600+ pages.
