Author Topic: 1947 KB3 2016 GMC 3500 chassis  (Read 72662 times)
Re: 1947 KB3 2016 GMC 3500 chassis
« Reply #15 on: February 17, 2023, 11:40:10 AM »
I've used the Ram Body Builder manual for some specs on my truck pretty often. Nowhere near 1600 pages of material though, that's got to be close to FSM. Nice find
« Reply #16 on: February 17, 2023, 02:13:03 PM »
ya that GM doc is what i tried looking at, its usless no connector pinouts, just endlesss wire diagrams- i gave up there.
still no fire, so i guess its a trip to shortsville to have a box unchecked on the tune.  all i can hope is that the starter motor diag shuts off more than the injectors (i have no pop with brake clean) and grounding the pin like stated on the forums doesn't change anything so not hopeful.
« Reply #17 on: February 20, 2023, 05:58:43 PM »
engine issue resolved. fired right up.
I had the Vats patch installed, but not enabled.  also did not have starter motor diagnostics disabled.  both of these items kept engine from firing.
all good now engine and trans.  on to more details / wiring.
glass, radiator, and a new starter motor showed up.
« Reply #18 on: March 15, 2023, 06:32:09 PM »
windshield frame got prepped and new glass today.
« Reply #19 on: March 20, 2023, 06:07:09 PM »
rest of cab glass done, doors rebuilt
floor patches and panels in, firewall patches done.
« Reply #20 on: March 29, 2023, 10:23:44 PM »
front bumper and front tin in.
used a chevy bumper.
made a dimple tool to press in some shape to the tin panels.
kinda cool.
« Reply #21 on: March 30, 2023, 08:10:22 AM »
Glad I came here to see the rest of the process after seeing the raw materials on FB... nice work.
Did Nick cut those out for you or are you just that good by hand with the plasma?
« Reply #22 on: March 30, 2023, 09:57:09 AM »
very cool
« Reply #23 on: March 30, 2023, 06:19:57 PM »
drilled two holes and then two plasma cuts with a straight edge for both plates, nothing fancy
« Reply #24 on: March 31, 2023, 08:44:44 PM »
Nicely done.
« Reply #25 on: May 05, 2023, 09:12:36 PM »
ran base lumber yesterday and started on the steel flatbed frame today.  should be finished up tomorrow if i dont get side tracked like i did today.
« Reply #26 on: May 06, 2023, 05:01:41 PM »
flat bed fab done.  need to finish some welding and move on to Frame attachment then lumber
always enjoyable on quick progress projects
« Reply #27 on: May 09, 2023, 09:38:52 PM »
finished up the flat bed today
started working on rear lights.
need to grab some metal for the rear hitch.
needs gas pedal mounted and plates.
« Reply #28 on: May 10, 2023, 09:08:42 AM »
Nice looking unit!
« Reply #29 on: May 11, 2023, 07:13:45 PM »
finished up the rear hitch today and adjusted the petals.
installed a brake controller and fuel gage.
submitted to hagerty to add insurance on it.
