Author Topic: 1930 Ford Model A Sedan  (Read 113960 times)
Re: 1930 Ford Model A Sedan
« Reply #120 on: May 13, 2024, 04:40:46 PM »
He was asking $60k... :o
I was watching a '29 Model A on bringatrailer today and it sold for 42k.
https://bringatrailer.com/listing/1929-ford-model-a-164/
« Reply #121 on: May 31, 2024, 11:11:03 PM »
Sandblasting off 94 year old paint...
« Reply #122 on: June 03, 2024, 07:13:38 AM »
Matte black.
« Reply #123 on: June 06, 2024, 08:07:15 PM »
looks good
what kind of paint are you liking to use?
i think the next one i do will be flat black or another red oxid primer.
« Reply #124 on: June 07, 2024, 09:53:44 AM »
SEM 39674
looks good
« Reply #125 on: June 10, 2024, 11:29:09 AM »
Temporally dropped the body back on the chassis, mostly to get it out of my way.  Collecting the next phase of parts & hardware.
« Reply #126 on: June 10, 2024, 12:11:02 PM »
lookin good!
« Reply #127 on: November 11, 2024, 09:25:11 PM »
That time of the year to get back into the shop.  I decided I wanted to give this car a little more oomph.  Going for a 500hp build.
Using this as a guide for the LQ9 I plan to put in the Chevelle.
« Last Edit: November 11, 2024, 09:28:35 PM by gif »
« Reply #128 on: November 11, 2024, 10:03:40 PM »
This is a LQ4 (6.0) with unknown miles.  I also didn't get to hear this one run before I pulled it, only got to hear it pop and stumble on starting fluid.    So I figured this would be a candidate for a rebuild.  And if I was going to rebuild it might as well throw some HP at it.  8)
 I have the engine completely apart and everything looks fine. All bearings look good.  Typical carbon and gunk.
I discovered that the best cleaner for carbon is easy off oven cleaner.  Then clean that with water with a little degreaser in it and then brake cleaner and air gun off. Finally coat everything with WD40 to not let it flash rust.
As usual, I got side tracked with the cleaning of the engine parts and decided to build a hot tank for the block. I had a 55 gal food grade barrel and a burner for oil fryer.  I added some copper tube with holes in it for air agitation.
« Reply #129 on: November 12, 2024, 03:18:29 PM »
« Reply #130 on: November 13, 2024, 10:53:46 AM »
 Engine parts for reference:
BTR Truck Norris Cam
BTR LS6 .560" Lift Beehive Valve Springs, Set of 16
BTR LS Truck Valve Seals Set of 16 VS LS HAT
Dura-Bond CH-25 Cam Bearing
GM 12646386 Original Equipment Timing Chain
GM 12556582 Original Equipment Crankshaft Sprocket
GM 12576407 Original Equipment Camshaft Sprocket
GM Camshaft Retainer Plate Gasket & Bolt Kit ARP 134-1003
GM Genuine Parts 12588670 Timing Chain Damper Kit with Bolt, Retainer, and Spacer
Michigan Motorsports LS Rod Bearings Standard Size SI-Series
Michigan Motorsports LS Main Crank Bearings Standard Size SI-Series
GM Genuine Parts 12639250 Rear Block Cover with crank seal
Michigan Motorsports LS3 Head Gaskets with 2004+ Head Bolt Kit
Hastings 2M5170 Stock Piston upgraded Premium Plasma Moly Rings
MELLING M295 Oil Pump
GM Genuine Parts 12573460 Engine Oil Plug
GM Genuine Parts  12560228 Engine Crankshaft Position Sensor
GM Genuine Parts 19420911  Camshaft Position Sensor
GM Genuine Parts 12677836 Engine Oil Pressure Sensor
GM Genuine Parts  19236568 Engine Coolant Temperature Sensor
302-2 GM Aluminum Oil Pan Kit F-Body for LS1 LS2 LS3 LS6, Rear Sump Pick Up & Gasket kit / Holly clone
102mm TB aluminum fabricated intake / Sniper clone.
Gates 45005 Premium Engine Water Pump
ACDelco Gold 38158 Drive Belt Tensioner Assembly with Pulley
ICT Billet Idler Pulley Bracket - Power Steering Eliminator Compatible with LSX LS1 Truck SUV Camaro LS3 ICT 551776-3
ACDelco Gold 38009 Flanged Idler Pulley
Allstar 87024 head pins
ICT Billet LS Engine Block Oil Threaded Passage Galley Plug 551283
ICT Billet LS Water Pump & Thermostat Bolt Kit 551434
ICT Billet LS oil Block Plug
Michigan Motorsports Valley Cover Gasket LS Performance Engine GEN III 97-2007 Gen 3
« Last Edit: December 07, 2024, 04:45:49 PM by gif »
« Reply #131 on: November 16, 2024, 02:59:33 PM »
Hot tank upgrades because I cant stop myself..   220V  5500watt heating element,  40a SSR,  Watlow 96 PID controller, Type K TC
Wired so I can plug into my welder extension cable.  Used the propane to help bring it up to temp. Then shut off the flame and let the controller take over at 130degs. Turned on the air and let it cook for 2 hours. Worked awesome.
« Reply #132 on: November 17, 2024, 03:34:52 PM »
Block rinsed off, dried and painted.    Next drove out the old cam bearings.  They look pretty hammered.
« Reply #133 on: November 17, 2024, 03:40:29 PM »
New cam bearings installed.
oil passage check with wifi scope
« Last Edit: November 17, 2024, 04:14:57 PM by gif »
« Reply #134 on: November 17, 2024, 04:47:56 PM »
Test fit of the cam.  Used a good assembly lube.  I just wanted to "feel" the fitment.  All good.   I will pull this back out before next steps.
