Author Topic: 1930 Ford Model A Sedan  (Read 113947 times)
Re: 1930 Ford Model A Sedan
« Reply #150 on: March 17, 2025, 11:14:10 PM »
I’ve never been successful with an oil pressure reading in Torque
« Reply #151 on: March 18, 2025, 01:43:31 PM »
I had it working on my Coupe build, so I knew it was available.
After messing with the PID editor in Torque, I got it working on this build.
Still need to verify the accuracy of my equation with a manual gauge.
I also want to log the AFR WB gauge, so I used the gauge 0-5v output wired to the EGR input on the PCM.
Blue connector Pin 55.  Then built a custom PID for that too.
Add a custom PID:
PID hex = 22115C
Long Name = Oil Pressure Calculated
Short Name = Oil Press
Min = 0
Max = 100
Scale Factor = x1
Unit Type = PSI
Equation = (a*0.65)-16.2
OBD Header = Auto
PID hex = 22114B
Long Name = EGR V
Short Name= AFR WB
Min = 10
Max = 20
Scale factor = x1
Unit type = 10-20
Equation = ((A/51)/.5)+10
OBD header = Auto
« Last Edit: March 28, 2025, 09:08:31 AM by gif »
« Reply #152 on: March 28, 2025, 09:54:03 AM »
All my rides have car audio of some type.  The previous Coupe build being the exception because of space limitations, and that always bothered me.
So I wanted to have some tunes in this car.  I did some research on open air options and the UTV style sound bars kept coming up.  UTV guys love them.  So i figured I would give one a shot. I narrowed it down to two of the largest ones on the market and went with the PowerBass XL1250.
On paper it sounded great. *pun*   Bluetooth to the phone as the source unit, simple power and ground connections, water proof, self contained package.
In real life it sounded like a 1980's boom box that was cranked up past the distortion levels on purpose.
Now granted, I am a car audio snob of the 90's era.  But damn, what a piece of $800 crap.
So I returned it and started looking into the new car audio offerings.
In my competition years I was rocking a pair of Phoenix Gold MS2125 and aMQ430.
In the past you had no idea what an amp could really output. But today YouTube has people with Amp Dyno's that test the amps for true output.
Picked my audio gear:
PowerBass XL-50BT UNIVERSAL BLUETOOTH RECEIVER
DOWN4SOUND JP95T WHITE GLOSS | 1500W RMS - 5 CHANNEL AMPLIFIER
CT SOUNDS MESO-6-5-COX // 150 Watts RMS 6.5 Inch Car Coaxial Speakers
CT SOUNDS HYDRO-10 // 500 Watt RMS 10 Inch Shallow Mount Subwoofer (2)
1/0 Amp Power and Ground w/ 250A ANL Fuse & Holder
12 & 14 Gauge Speaker wire
Triple shielded RCA cables
« Reply #153 on: March 28, 2025, 10:03:50 AM »
I built a sub / amp box that fits tucked all the way in the rear of the Sedan and gets bolted in place.
Its made of 3/4 MDF and is screwed and glued together. Normally I would cover the box in non-backed carpet. But this time I wanted something with a clean look.
I found speaker cabinet paint fit the bill perfect.  Its the stuff you would find on portable DJ equipment or on concert speakers.
I am just about ready for final assembly and install.
« Reply #154 on: March 28, 2025, 10:47:22 AM »
the cabinet paint looks great. more textured than what I'm used to seeing, almost looks bedliner-ish? looks like it hides the joints pretty well
« Reply #155 on: March 28, 2025, 11:12:54 AM »
Yes, very bedliner-ish, but hard finsh.  Comes out of the can like thick pudding.
« Reply #156 on: March 28, 2025, 11:30:20 AM »
Nice!  I used to be big into car audio back in the day.
« Reply #157 on: March 29, 2025, 11:32:38 PM »
Installed and tuned. Needs a timer relay for the turn off sequence.  Other than I'm pretty happy with it.
It sits on top of the gas tank access panel. Its bolted at the base and the roof frame.  The two side panels (tranny cooler & Battery) are still fully accessible.
Also got all the roof jute installed.
« Reply #158 on: April 03, 2025, 08:55:32 PM »
Rolled out under its own power.
Getting closer with the GUI dash layout.
GUI background is a pic of the bare dash.
Probably going to need to raise the rear 1.5"
« Last Edit: April 03, 2025, 09:12:24 PM by gif »
« Reply #159 on: April 04, 2025, 08:02:20 AM »
Nice!
« Reply #160 on: April 07, 2025, 10:49:37 AM »
I adjusted rear coilovers to add 1.5" of ride height.  Sits perfect now.  If I need more I will need to go up in spring rate.
Took it for a quick drive around the block.
Ride position feels good, I definitely fit in this one better. Visibility is ok. Steering feels great. Brakes are firm (non powered).
A built 6.0 is a lot of engine for this little car.  I already scared myself!
Punch list:
1) Windshield glass
2) Weepy caliper bleeder
3) Maybe a backup camera
Once I get it on the road I can start tuning the engine and trans.  Right now Im forcing it to run on the MAF fuel calibration.
During my drive around the block I noticed it wanted to shift in to 4th sooner than I would want.
« Reply #161 on: April 07, 2025, 04:47:03 PM »
Sunlight !
« Reply #162 on: April 07, 2025, 08:46:24 PM »
Sharp work as always!
Sent from my SM-S928U using Tapatalk
« Reply #163 on: April 08, 2025, 12:37:14 AM »
« Reply #164 on: April 08, 2025, 11:28:08 AM »
