Author Topic: 1951 L110  (Read 16485 times)
Re: 1951 L110
« Reply #30 on: June 30, 2022, 04:03:16 PM »
looking pretty damn sweet!
Re: 1951 L110
« Reply #31 on: June 30, 2022, 06:03:29 PM »
Perfection
Re: 1951 L110
« Reply #32 on: July 02, 2022, 05:41:10 PM »
steering and brake controls in today 100%
kept the adjustable height Denali petal setup after some wire diagram and some google foo- should be tits on a toggle switch.
also took some time with 0000 steel wool on the front driver quarter, and there is actually some shiny paint on this thing left in some places!  looking good!
Re: 1951 L110
« Reply #33 on: July 04, 2022, 07:41:07 PM »
started on wiring.  should be running and moving soon...
Re: 1951 L110
« Reply #34 on: July 05, 2022, 12:42:30 PM »
motor fired.
a ground got lost on the TAC module- was same symptom of have active VATS, but PCM tested good on the other 6.0 truck i have here.
ground must have come from the body control module / cruise package connector where i cut it.  ill have to remember that one.
sounds good.  working on rad install that brown truck brought just in time lol
Re: 1951 L110
« Reply #35 on: July 05, 2022, 05:11:26 PM »
Coolant bled.
boo for a bad voltage gage in the 3 pack cluster  (bought 4 of them last summit order and last one left)
checking off wiring items and finishing up under hood, then moving to cab/glass/seat.
Re: 1951 L110
« Reply #36 on: July 05, 2022, 10:39:09 PM »
all plumbing 100% done on tonight's night shift.
need to order an air filter
Re: 1951 L110
« Reply #37 on: July 12, 2022, 05:54:06 PM »
started on glass and door rebuilds today.
swapped out a DOA bosch voltage gage with an amazon unit (back light color is different BAH!)
Re: 1951 L110
« Reply #38 on: July 16, 2022, 09:13:04 PM »
pretty much done.  rips down the road hard.
might need a water pump, something leaking a bit.
a front bumper and some rear glass gaskets would finish this truck 100%
need to insure and plate next week.  should be a fun one.
already have a buyer that viewed and begged to put a deposit down ( i held off till its 100% on road and transferable papers in hand)
Re: 1951 L110
« Reply #39 on: July 26, 2022, 12:30:41 PM »
4100lbs on the scales
Re: 1951 L110
« Reply #40 on: July 27, 2022, 02:42:39 PM »
first good drive.  no complaints.  noticed the water pump weeping last week so that will need to be addressed.
6.0 awd rips and exhuast is not bad.  no rattles tight cab.
need to track down a front bumper, rear glass seals, and some wipers.
gas filler neck or tank venting is screwed up- can only be filled SUPER slow
Re: 1951 L110
« Reply #41 on: July 30, 2022, 05:42:59 PM »
too much fun
probably sending it to buffalo and back tomorrow for first real trip.
charges, cools, gages good for 2 20min drives today.  topped off coolant, doesnt seem to be weeping from WP any more.
passed brett and Ashley in the TJ today but didnt click who it was fast enough to wave, i think same for brett haha
Re: 1951 L110
« Reply #42 on: July 31, 2022, 06:57:11 PM »
ripped this guy to buffalo and back today.  water pump leaky leaky so picked up one on the way back to change out tomorrow when it cools off.
otherwise, thing is sweet on the thruway.  no issues with motor or trans hot.  slams gears and rips.
lots of smiles and waves.
Re: 1951 L110
« Reply #43 on: August 05, 2022, 04:37:33 PM »
last 10 feet of universal glass seal on the internet close to what i need i could find was brittle junk from Thialand that probably had sat on a shelf for 16 years.  tore like Kleenex even with lube when tried to install.
bah, amazon can eat that back.  i guess ill just order and wait till its back manufactured bah!
Re: 1951 L110
« Reply #44 on: August 05, 2022, 04:52:18 PM »
ordered real seals.  hopefuly sept26 delivery is worst case lol
its actually nice having the back windows open for air in the summer
