Author Topic: Dump II: Santa's Ride  (Read 34545 times)
Re: Dump II: Santa's Ride
« Reply #15 on: June 01, 2012, 09:06:37 PM »
That sounds right. Search converting fs to fso transmission you will see some of the info. I have seen a lot with the 6 speeds so I am not sure about the 5 speeds
« Reply #16 on: June 03, 2012, 01:33:46 PM »
False info I found online!! There is only a few models that you can convert.
« Reply #17 on: June 03, 2012, 04:11:53 PM »
figures... :'(
« Reply #18 on: June 04, 2012, 11:37:03 AM »
Mike did you have good luck with caseys? I can not get them to call me back to tell me if they have the exact transmission I want and how much. bassstids!!
« Reply #19 on: June 04, 2012, 11:40:49 AM »
I did have good luck. I don't remember which guy I usually talked with. The old guy (who I think is Casey himself) is pretty forgetful. I dealt with one of the younger guys there. Shit, they might even remember my project and pile, that might loosen them up a little for you. They all have Cummins Rams but the one I dealt with had actually been thinking about a swap.
« Reply #20 on: June 04, 2012, 11:47:46 AM »
I will mention it next time I talk with them. They are supposed to be calling me back in a little bit which means I will be calling them again around 1 to remind them.
« Reply #21 on: June 04, 2012, 03:50:25 PM »
2450 for a rebuilt fso-6406a which is a 6 speed overdrive fuller from caseys. That price includes transmission bell housing and a yoke. I am really leaning towards pulling the trigger on this since I can't  wait for a couple months to try and find a good deal on one. What did your total build run you mike?
« Reply #22 on: June 04, 2012, 04:01:04 PM »
3750 with clutch and housing and starter [that didn't clear] and yoke and joint and shifter and stuff. _complete_
« Reply #23 on: June 04, 2012, 04:01:30 PM »
that is not bad, you could sell some of your 4500 and gear venders to make most of that back
« Reply #24 on: June 04, 2012, 04:07:06 PM »
I bet I will have no problem getting 3500-4000 for my whole setup if I fix what is wrong with my 4500. I will also buy the fuller 6 speed from ontario truck parts he will sell me clutch flywheel everything for 500 dollars then I can try and resell that transmission for maybe 750 so I think in the end I can probably do a even slide if not make a little money.
« Reply #25 on: June 04, 2012, 04:11:13 PM »
alright now you are smoking the same crack mike does, you should be set now
« Reply #26 on: June 04, 2012, 04:14:23 PM »
hahahahahaaa
« Reply #27 on: June 04, 2012, 04:19:23 PM »
HahahahahhahHah  type dodge nv4500 into ebay then look for a conversion one and look at the price. Then search gear vendor and put the prices together and tell me I am still on crack!!
« Reply #28 on: June 04, 2012, 04:21:44 PM »
my 4500 4x4 setup sold in less than a week for 1500 I think? clearly could have gotten more.
« Reply #29 on: June 04, 2012, 04:24:15 PM »
I see just transmissions all over for 2k with no clutch or transfer case
