Author Topic: Dump II: Santa's Ride  (Read 34511 times)
« on: May 04, 2012, 04:45:30 PM »
Nick, here's some ratio tables for you:
http://www.truckplace.com/parts/transmission/eaton.shtml
Conversion parts list:
http://www.sanco-bg.com/NV5600_Conversion_parts_list.htm
my build - few other links in there:
http://www.pirate4x4.com/forum/showthread.php?p=14328064
I think all the pics are gone from this thread, but it's the one I was talking about with the adapted married tcase.
http://www.cumminsforum.com/forum/98-5-02-powertrain/86188-roadranger-10-speed-conversion-can-done.html
Re: Dump II: Santa's Ride
« Reply #1 on: May 04, 2012, 11:55:56 PM »
Sweeeeet I will take a look once I get on a computer. I am leaning to the 6 speed at OTP chatters talked with steve he said 4-500 for the transmission. I will be able to get the clutch and flywheel also with that.
« Reply #2 on: May 05, 2012, 08:50:56 AM »
if you have a source for NV5600's for 500$ i would buy 6 of them to easily double or tripple your money on ebay or any diesel forums
« Reply #3 on: May 05, 2012, 09:01:38 AM »
that sounds like a steal nick I would jump on it.
« Reply #4 on: May 05, 2012, 09:36:39 AM »
They are not 5600 they are eaton 6 speeds out of something semi big. It is not going to be a dump bus but it sure will be a dumper! I am gonna look around a tad more see if I can find a overdrive 6 speed that would be sweet. I really don't wanna use my gear vendor again since now that is just going to be a weak link and a hassel in the future. Then after this project will be looking for a f550 with a blown motor and put my truck drivetrain in that and buy a 10 ton goose trailer for that setup. Now that will be the bees knees!
« Reply #5 on: May 05, 2012, 11:56:27 AM »
Bees knees :o
« Reply #6 on: May 05, 2012, 11:59:05 AM »
What do you need to get out of the gear vendors?  I have a guy looking for one possibly.
« Reply #7 on: May 05, 2012, 01:34:19 PM »
I will keep it in mind. If I am going to get rid of it I will be doing it as a package with the transmission tho so we will see
« Reply #8 on: May 05, 2012, 02:27:12 PM »
They sure seem overpriced and weak
« Reply #10 on: May 31, 2012, 10:26:27 PM »
« Reply #11 on: June 01, 2012, 01:07:25 PM »
F-6406A-ASW FS-5106A FS-5306A FS-5406A FSB-5406B FS-6206A FS-6306A FS-6406A FSB-6406B FO-6406A-ASX FO-8406A-ASX FO-6406A-ASW FSO-6406A FSO-8406A FS-7206A FS-8206A FS-8306A
« Reply #12 on: June 01, 2012, 02:08:44 PM »
Mark I am not sure what transmission you have in the BBB but if it is a fuller 6 speed from what I am reading it is easy to cover a direct drive tranny to a OD. I have a good cheap lead on a fuller 6 speed direct drive and I will be swapping it over to a OD.
« Reply #13 on: June 01, 2012, 04:09:47 PM »
It's a Fuller 5 speed but I'm not sure what model.  Model number later...
« Reply #14 on: June 01, 2012, 08:37:38 PM »
Eaton-Fuller FS-4205A?
« Last Edit: June 01, 2012, 08:39:51 PM by Wingman »
