Author Topic: H1 Insert Tech  (Read 42664 times)
H1 Insert Tech
« on: February 10, 2021, 09:19:13 AM »
Grabbed a set of 37" Baja T/As on 12 bolt H1s for $150 to throw on my Jeep once my 39s are on my buggy. No inserts though.
I know there is a lot of H1 knowledge in this crowd from ~10 years ago...
What were people using for inserts? What size PVC? Where did you get it? What modifications, if any, did the PVC need to work correctly? Is the width cut anything more than measuring the assembled wheel and subtracting both bead thicknesses?
There is a $100 set of stock rubber runflats locally I am tempted to grab but am reading not all tire and wheel combos are interchangeable.
Re: H1 Insert Tech
« Reply #1 on: February 10, 2021, 09:51:43 AM »
magnesium came with mine and eventually got cut down. I never made drain pipe ones.
Re: H1 Insert Tech
« Reply #2 on: February 10, 2021, 09:54:50 AM »
I think you only run into issues with thickness of the stock ones when going to something with really thick sidewalls like a bogger or tsl
the rubbers are a total cunt to get into and out of a tire, all second/thirdhand.the bigger the tire the easier I'm sure but you may end up wanting to cut those down anyway. but for $100, maybe that's worth it.
Re: H1 Insert Tech
« Reply #3 on: February 10, 2021, 10:27:36 AM »
Trailworthy sells ready to go PVC inserts for $70ea and charges $100 for shipping. Definitely the easiest option, but I'm not ready to spend $400 on this without some more research I don't think.
Re: H1 Insert Tech
« Reply #4 on: February 10, 2021, 10:37:44 AM »
SD17 is the sewer pipe size you want to cut them out of
cutting the mag ones down is also fine, just take not of where the chips go, because mag dust goes up in flames very easy
the rubber ones can be cut down east also if left outside in frezzing temps and a chain saw will buzz right through them
personally the mag ones were the least hassle to install and mot reliable for me.
Re: H1 Insert Tech
« Reply #5 on: February 10, 2021, 10:43:43 AM »
troy and i made a jig with a couple wheels and a circ saw to cut the sewer pipe.  dont remember the dimention we set on.  you can also cut an interlock feature so they collapse to install with a plate and bolts to hold them in.   there might be pics somewhere on this form
Re: H1 Insert Tech
« Reply #6 on: February 10, 2021, 12:06:29 PM »
Looking around a little more, it seems not difficult to cut out excess circumference from a larger size of PVC and make it work. Hopefully DJ has something kicking around...
https://www.pirate4x4.com/threads/pvc-beadlock-inserts-hummvee-wheels.537679/
Re: H1 Insert Tech
« Reply #7 on: February 21, 2021, 09:41:24 PM »
Gettin it done! Enjoying the 2006 pirate reads on how to do it.
Re: H1 Insert Tech
« Reply #8 on: February 26, 2021, 08:06:37 PM »
Done. Let me know if anyone sees any 16.5” 40”+ tires on the cheap...
Re: H1 Insert Tech
« Reply #9 on: February 26, 2021, 10:17:36 PM »
Is this where one of us points out that 16.5s really are 10+ years on dead?
Lol
Nice work
Re: H1 Insert Tech
« Reply #10 on: February 26, 2021, 10:37:01 PM »
Lol
Nice work
16.5s are dead. But. Reds don’t work 3 months out of the year. Big dumb cheap Interco whatevers at low psi will do what I need.
Re: H1 Insert Tech
« Reply #11 on: February 27, 2021, 07:16:50 AM »
Nice!
Re: H1 Insert Tech
« Reply #12 on: February 27, 2021, 07:16:50 AM »
Nice!
Re: H1 Insert Tech
« Reply #13 on: February 27, 2021, 08:43:54 AM »
And big dumb intercos can be found from 15 years ago :)
Re: H1 Insert Tech
« Reply #14 on: February 27, 2021, 10:01:45 AM »
someone sounds a little butt hurt that the XJ has def beat the dakota in potato chip status ;D
