Author Topic: new house for mikemike  (Read 251285 times)
Re: new house for mikemike
« Reply #75 on: May 26, 2020, 09:24:09 PM »
Useful vaporizer? What I have on the way is that standard J or whatever it is.
Could definitely use an operational forktruck to clean this shit up
I needed to dig out four of the very most buried tires. Someone clipped a curb... and got to be first on a lift before any of my junk.
Joe is maybe an hour from emptied out now. Load in Gus to the house. Few more of those on the horizon
Gonna put the ATV tires back on Gus for now. Tired of spinning in the yard when empty.
House garage door decided not to. Don’t know why yet.
« Reply #76 on: May 26, 2020, 09:32:15 PM »
mixer with butterfly and coolant heated regulator.  basically everything needed to put over an intake hole of a motor with good ignition, minus some hose barbs and LPG line.
« Reply #77 on: May 26, 2020, 09:59:33 PM »
It’s the vaporizer + regulator piece that I’m needing. Looked it over when dad was here, should be easy to abandon what’s there and install, I hope.
I won’t have what I bought until saturday. Might be worth it to me to grab it Thursday. Tomorrow is full with getting diesel, mowing, meeting.
Kinda can’t wait for those furlough weeks. In a normal year I’d have probably taken 3 weeks vacation for this now.
« Reply #78 on: May 27, 2020, 07:18:48 AM »
screwing on those replacement pieces will be way easier than what would be required to change to use what i have.  id def try that first.
probably 2-300$ in value of the stuff i have also now that i think about it.
« Reply #79 on: May 27, 2020, 07:27:15 AM »
This or something like it isn’t one of those pieces?
IMPCO JB Forklift Fuel Converter with Blue Spring https://www.amazon.com/dp/B009SEITFC/ref=cm_sw_r_cp_api_i_A5KZEbMBZFKFC
« Reply #81 on: May 27, 2020, 08:51:33 AM »
damn, that's a lot of tires
« Reply #82 on: May 27, 2020, 09:50:57 AM »
mowed for about 90m before work today. got well more than half done. Wishing for 15 more horsepower. I did not look at the blades yet.
going across the grain in the back is rough, that's a fair bit of ruts. Need to override the mower disconnect and change it to a tether or something. Going across crossgrain bumps in back I get off the seat enough to disengage.
« Reply #83 on: May 27, 2020, 10:07:28 AM »
could a turbo be added to that mower's diesel motor?
« Reply #84 on: May 27, 2020, 10:11:58 AM »
Easily - but adding appropriate extra fuel isn't easy.
If that motor was available as a turbodiesel, I might be able to find the appropriate fuel pump - I bet it would cost near as much as the mower cost me though. And often the turbo versions have lower compression and more durable internals.
« Reply #85 on: May 27, 2020, 10:13:29 AM »
Just signed a stipulation of assessment at 260k and sent it back to the assessor. Still needs board approval but that's all but a given.
« Reply #86 on: May 27, 2020, 11:13:35 AM »
confirmed receipt, should get a letter from the board within 10 days confirming adjustment 👍
I didn't use 5 gallons mowing the first time - thought it was low and bought 10 gallons this morning, only added maybe 4 to the brim.
« Reply #87 on: May 27, 2020, 03:35:53 PM »
Just dropped off
« Reply #88 on: May 27, 2020, 03:45:55 PM »
o my
« Reply #89 on: May 27, 2020, 03:46:28 PM »
What happened PO took it?
