Author Topic: new house for mikemike  (Read 226780 times)
Re: new house for mikemike
« Reply #420 on: October 25, 2020, 09:48:07 PM »
Second fire downstairs, had to remove a relatively large bird from the chimney. Alive and well, so recent entrant. Too large to fly back up, i pulled the new cap off the bottom. But apparently small enough to fit between the chimney cap louvers. Also a bit of a puddle on that bottom cap. So perhaps there’s a top cap issue. Looked good from the ground in the dark.
« Reply #421 on: October 26, 2020, 07:04:35 PM »
Found by Titan this afternoon while I was at work, outside the shop.
« Reply #422 on: October 27, 2020, 06:57:54 PM »
It’s a keeper?
« Reply #423 on: October 27, 2020, 07:54:37 PM »
So far!
« Reply #424 on: November 08, 2020, 11:42:49 PM »
Remotes on all four garage doors.
Hope range isn’t TOO good - the buttons really hang out and are easy to accidentally push in a pocket.
Got four of these, using three. Was able to share one recover for two of the shop doors since they have two relays. Found single button control contacts on all openers. Pretty sweet!
« Reply #425 on: November 09, 2020, 09:21:29 AM »
These are the remotes used.
Solidremote 12V - 24V Secure Wireless RF Remote Control Relay Switch Universal 2-Channel 433MHz Receiver with 2 FCC ID Transmitters for Garage Door Openers, Cars, LED Lights & More (KIT-1) https://www.amazon.com/dp/B01JGDV8UM/ref=cm_sw_r_cp_api_fabc_qavQFbXXETB0J?_encoding=UTF8&psc=1
« Reply #426 on: November 10, 2020, 10:24:57 AM »
Got all excited about buying a trencher. Home Depot tool rental has one for sale CHEAP in Batavia.
Store says the site is frequently wrong and that unit isn’t for sale.
So, still need to rent one to run power and water and network. Humbug.
« Reply #427 on: November 10, 2020, 11:01:01 AM »
HD and Lowes websites are such garbage.
« Reply #428 on: November 10, 2020, 03:12:47 PM »
There's a admar satellite location in canandaigua, not sure if they rent to the public though
« Reply #429 on: November 10, 2020, 03:53:51 PM »
$150ish for a 4hr rental or 200ish for 24hr from Victor Depot. Did it for the gutter drainage.
« Reply #430 on: November 10, 2020, 05:26:30 PM »
Fingerlakes Equipment Rental in Geneva $125/day for 18" trencher $250 for a larger one.
« Reply #431 on: November 14, 2020, 12:39:02 PM »
Problem solved. Likely for sale open market in the spring. Available for use or sale at my cost ‘till then.
« Reply #432 on: November 14, 2020, 02:27:17 PM »
you are an animal!  nice!
« Reply #433 on: November 14, 2020, 04:16:39 PM »
And as with every used equipment purchase: deferred maintenance item bit me.
It’s a good unit but the end bearing was seized. That wasn’t compatible with my rocky backfill. Parts available. Just a delay.
« Reply #434 on: November 21, 2020, 05:47:35 PM »
Not having a fun time with pull string through 1/2” pvc conduit. But it’s all in the ground and buried. Shop wired network is all dressed. Need to do both ends on the stable power still.
