Author Topic: 1971 Series 2a  (Read 39250 times)
Re: 1971 Series 2a
« Reply #135 on: September 29, 2018, 10:24:03 AM »
What tires are those?
Re: 1971 Series 2a
« Reply #136 on: September 29, 2018, 10:46:46 AM »
7.50 x 16 michelin XZL's
Re: 1971 Series 2a
« Reply #137 on: September 29, 2018, 06:26:42 PM »
At least it looks done..
Re: 1971 Series 2a
« Reply #138 on: September 29, 2018, 07:08:38 PM »
Time for plates?
Re: 1971 Series 2a
« Reply #139 on: September 29, 2018, 10:45:54 PM »
Vintage plates... got them. And a sticker already
Re: 1971 Series 2a
« Reply #140 on: October 01, 2018, 08:32:27 AM »
Some first driving impressions... granted only up and down the street.
Clutch needs adjusting... not super smooth shifting unless you stomp on the clutch pedal
Brakes need adjusting... stopping takes some planning
Carb needs adjusting... idle, etc
1st gear almost not needed, can start in 2nd because of the low end torque in this motor
Top speed will be typical rover depending on rpm
Need to calibrate the rover sending unit / gauge to the Buick engine...
speedo not working, possibly missing drive gear
Re: 1971 Series 2a
« Reply #141 on: October 01, 2018, 03:22:05 PM »
this was the motor i pulled out of the jeepster?
cool!
Re: 1971 Series 2a
« Reply #142 on: October 01, 2018, 03:22:48 PM »
Vroom vroom 😉
Re: 1971 Series 2a
« Reply #143 on: October 05, 2018, 02:28:01 PM »
Re: 1971 Series 2a
« Reply #144 on: October 05, 2018, 02:50:37 PM »
Been debating picking those up
Cheap insurance of I want to ever run flotation tires...
Re: 1971 Series 2a
« Reply #145 on: October 12, 2018, 07:06:17 AM »
Hopefully a differential swap this weekend...(rear only for now)
The little bit of driving I have done has been over 3k rpm
Going from 4.70 series diffs to 3:54 Range Rover diffs...
Re: 1971 Series 2a
« Reply #146 on: October 15, 2018, 08:39:06 AM »
swapped the rear diff this weekend for a later Ranger Rover 3:54..
had to get creative and fill the axle through the vent.. didn't notice the lack of a fill plug until everything was all buttoned up..
Truck is much happier with the new gears.. first gear is usable and still punchy.
I took the front drive shaft out to prevent any unforeseen issues until I can get around to swapping the front. Rear took 90 min to R&R.. I have a feeling the front will take a tad longer.
Also got around to buttoning up the transmission tunnel.
This is version 1 of what will eventually be a single piece of bent aluminum..
plenty of room for 4wd levers..
Re: 1971 Series 2a
« Reply #147 on: October 24, 2018, 01:32:46 PM »
Clutch issue reared its ugly head last week..
After an uneventful afternoon of driving (some hard shifts) I lost clutch control..
the clutch would not disengage with the pedal depressed, and I was unable to shift transmission into gear..
I cursed and screamed about this for a week... thinking i would heave to tear into the truck again and that i had an issue..
finally got some time this AM to crawl under the truck and pull the slave cyl.
upon removal i noticed the slave rod was shorter than when it went into the truck..
despite the lock nut on the rod, I have a feeling the vibration of the odd fire wiggled this guy loose.
I haven't tested anything yet, going to throw a tack weld or 2 on the lock nut and reinstall tonight..
fingers crossed
Re: 1971 Series 2a
« Reply #148 on: December 20, 2018, 08:39:20 AM »
got back in the garage last couple weeks to start a refurb on the heater..
had the main housing blasted and core pressure tested.. couple of pinholes were revealed from trapped leaves.
JB weld to the rescue!
Blower motor disassembly wasn't ideal and I'm currently searching for parts..
Bulkhead hold cut and everything test mounted last night before final assembly.
there is some interference from the bonnet support and inner wing.. going to have to play around with both.
Heater moved outboard just enough that it misses the indents
Also the heater intake and hole in the wing don't exactly match up for a solid connection.. I'm thinking some ducting will be just fine there.
When mounting the heater core, there was some caulk type stuff on the fins of the core insulating it form the heater body.. is that just strip caulk or something else?  would felt be better?
I already planned on using strip caulk for the flanges of the heater and interior distribution box.
just need a blower wheel now..
Re: 1971 Series 2a
« Reply #149 on: December 20, 2018, 10:27:54 AM »
whatever material that won't degrade too fast that seals around the edges and prevents rattles would be fine IMO. Something closed cell (not felt) probably better so it isn't as prone to holding moisture against the core and box is probably best?
