Author Topic: 1971 Series 2a  (Read 39294 times)
Re: 1971 Series 2a
« Reply #120 on: August 03, 2018, 10:58:02 PM »
Not sure what’s the end plan electrical wise but why not put most/all wiring, cable, starter solenoid inside that under seat compartment? For a cleaner under hood.
Re: 1971 Series 2a
« Reply #121 on: August 03, 2018, 11:11:51 PM »
I have some fire sleeve if you need a couple feet for that driver side valve cover area. Used it for running either my starter or winch power behind the header, forget which.
Re: 1971 Series 2a
« Reply #122 on: August 04, 2018, 06:11:53 PM »
Cleaner means more work if there is a problem...
I’m ok with the looks, just dislike the remote battery..
I’m going to order a longer cable and run on other side of pedal boxes..
Re: 1971 Series 2a
« Reply #123 on: August 06, 2018, 02:51:55 PM »
longer cable on the way..
putting juice to it this week..
Re: 1971 Series 2a
« Reply #124 on: August 20, 2018, 09:31:05 AM »
Despite electrical success unseen problems happen..
Couple of pictures as to what I’m dealing with...
Went to start the motor yesterday, filled and bled clutch, no engagement.
I wasn’t getting any clutch action due to the fork hitting the back of the housing window.
Made a longer pushrod (before we had housing contact) and things just got worse.
Despite kicking myself and cursing, gearbox removal is rather simple... floors and seat come out and transmission gets lifted up rather than down.
Tranny out and throwout bearing proved evidence of perhaps something else.   I think constant pushing on the fork the input shaft acted as a wedge and I had enough force to bend the back...
any thought?
There appears to be no surface wear on either clutch pressure plate or bearing...
I think this comes down to fork or bearing height and travel allowed..
Calling Novak and getting an adjustable bearing and ball stud..
I have a few clutch arms in stock, should have enough to cobble something together.
Re: 1971 Series 2a
« Reply #125 on: August 20, 2018, 09:43:33 AM »
So there is no clutch engagement at all?
Re: 1971 Series 2a
« Reply #126 on: August 20, 2018, 11:09:41 AM »
This.
 I think you meant there’s no disengagement?
Re: 1971 Series 2a
« Reply #127 on: August 20, 2018, 11:43:29 AM »
Syntax aside
When you engage the pedal it doesn’t disengage the clutch..
It’s deff a bearing height issue...
Re: 1971 Series 2a
« Reply #128 on: August 24, 2018, 02:04:11 PM »
Parts ordered, research done...
Taking Monday off to get this thing rolling..
Re: 1971 Series 2a
« Reply #129 on: August 28, 2018, 09:23:00 AM »
moved under its own power...
still lots of fiddly things to do though..
Re: 1971 Series 2a
« Reply #130 on: September 17, 2018, 01:54:53 PM »
functioning 100% still have not road tested..
working on the stupid stuff now...
16" wheels at the blaster
needs exhaust
floor and trans tunnel the focus now
door alignment being a bit of an issue..
engine compartment tidying
some interior trim and weather stripping last to do...
Re: 1971 Series 2a
« Reply #131 on: September 17, 2018, 03:30:21 PM »
jigsaw puzzle all back together!
Re: 1971 Series 2a
« Reply #132 on: September 21, 2018, 10:23:28 AM »
blasted... getting fresh color
Re: 1971 Series 2a
« Reply #133 on: September 22, 2018, 07:07:51 PM »
Dropped for exhaust today..
Wheels should be painted this week and rubber mounted..
 ;D
Re: 1971 Series 2a
« Reply #134 on: September 29, 2018, 08:45:54 AM »
Now waiting on truck
