Author Topic: JEEPWERX CJ7 Buggy Style  (Read 75335 times)
Re: JEEPWERX CJ7 Buggy Style
« Reply #210 on: July 25, 2014, 08:50:27 AM »
I paid that for 4 boggers
« Reply #211 on: July 25, 2014, 08:51:35 AM »
sorry
« Reply #212 on: July 25, 2014, 08:52:07 AM »
I'm not. It's what I wanted at the time.
« Reply #213 on: July 25, 2014, 08:56:19 AM »
my 44's were blems and 2100 shipped i think
it wasnt what i wanted but i had to do it haha
« Reply #214 on: July 25, 2014, 09:01:02 AM »
Boggers are stupid and Fun...
Just like my Buggy!
OH I ALMOST FORGOT!
IT LIVES, and it sounds mean as shit!
« Reply #215 on: July 25, 2014, 09:03:05 AM »
Tonights list =
Steering pump install
Steering cooler install
Rear brake lines
Wire all  3 fans
Air shocks reinstall and pressurize
« Reply #216 on: July 25, 2014, 09:13:56 AM »
cool!
« Reply #217 on: July 25, 2014, 09:26:41 AM »
And an alternator.
Apparently I broke the stud off the back of the alternator when disassembling the engine for removal. Got one coming in to nu-way Farmington tomorrow AM . Its only 70 amps so I'll upgrade at a later date
« Reply #218 on: July 25, 2014, 09:35:52 AM »
Almost as bad as seeing what government pricing is compared to my cost. Makes me sick.
« Reply #219 on: July 25, 2014, 10:29:05 AM »
Can't imagine
« Reply #220 on: July 26, 2014, 02:35:03 PM »
Cooler fans wired to ignition or seperate switch?
They will be thermostatically controlled so I don't see the need for a separate switch.
What  do you guys do?
« Reply #221 on: July 26, 2014, 02:52:27 PM »
I say ignition, you can always pull the fuse if you need to shut them off. Unless you want to switch off for deep water fording...
« Reply #222 on: July 26, 2014, 03:02:01 PM »
I don't have fuses.
I went with circuit breakers
Both fluid coolers are 5.3 amps each
Not sure what the radiator fan is. For now it's a junkyard take off.
10 gauge wires to it so I may wire it to its own switch / circuit breaker.
I don't want to over load the 20 amp ignition switch / breaker.
« Reply #223 on: July 26, 2014, 07:32:19 PM »
I need to move mine to ignition, you will leave it off!  Can put a solenoid or relay in.  You have separately mounted fluid coolers?
« Reply #224 on: July 26, 2014, 07:52:18 PM »
My previous set up had it on a seperate switch. Took some getting used to.
But I'm trying to eliminate fuses on this go around so for now radiator and fluid coolers are on seperate switch with circuit breakers.
I'm running the same type of remote fluid coolers as 572.
Derale 16 pass w 10 " fan on thermostats.
