Author Topic: JEEPWERX CJ7 Buggy Style  (Read 75319 times)
Re: JEEPWERX CJ7 Buggy Style
« Reply #180 on: July 23, 2014, 01:45:25 PM »
How else do I figure out the sprung weight then by weighing the entire vehicle first.
Then jack up the chassis to pick it off the bump stops.
Subtract that measurement from total weight.
Race scales sound perfect.
« Reply #181 on: July 23, 2014, 01:45:44 PM »
Race scale procedure: get corner weights with no springs or shock pressure, sitting on bump stops. Then put the chassis on jackstands off the stops to get the unsprung weight and subtract.
That's my thought, anyway...
good idea, add measure angles of shocks at ride height also
« Reply #182 on: July 23, 2014, 01:46:35 PM »
I forgot about angled shocks. very true.
« Reply #183 on: July 23, 2014, 01:47:21 PM »
Different spring rates offer different dampening effects.
100 over 350 would be better for a rock crawler.
« Reply #184 on: July 23, 2014, 01:47:56 PM »
Need some trig to go from the scales to per-inch weights on the shocks but you're a carpenter. You understand angles :)
« Reply #185 on: July 23, 2014, 01:48:59 PM »
This is may all be a touch too technical for this buggy.
she is no Ultra 4 car
« Reply #186 on: July 23, 2014, 01:50:16 PM »
100/300 and 200/200 give the same total rate before the dual rate stop but the 100/300 gives you three times the rate after you hit the stop. much more progressive so you don't crash through your travel.
right?  EDIT: no, I think I'm wrong on that. It's not a+b/2 for total rate, it's something else....
I'd think we actually want more progressive on the gofast than for a crawler that wants to end up using all travel.
Things that probably belong in a suspension tuning thread?
« Reply #187 on: July 23, 2014, 01:50:18 PM »
I do understand angles... ;)
« Reply #188 on: July 23, 2014, 01:50:32 PM »
spring rate does not relate anything to dampening
i believe rock crawlers like single rate (no dual stops, and same upper/lower) because they want smooth consistant suspention travel, not like a racer on an O SHIT jump stop my car from EXPLODING on landing
« Reply #189 on: July 23, 2014, 01:52:13 PM »
right?
almost, but 100/300 is total rate of 75, 200/200 is 100
« Reply #190 on: July 23, 2014, 01:53:19 PM »
1/Kt = 1/K1 + 1/K2
« Reply #191 on: July 23, 2014, 02:07:45 PM »
for that car i would get 3pairs of 150, 1 pair of 200, 1 pair of 250
2.5x14x150  2
2.5x16x150  2
2.5x14x200  2
2.5x16x200  2
2.5x14x250  2
That should cover you for most situations. maybe an 18"x200 but I think 2 16" on those will work just fine.
DO you have limit straps?
« Reply #192 on: July 23, 2014, 02:10:57 PM »
I just checked pricing at VC, looking at about $38 per coil depending on size, Plus shipping.
« Reply #193 on: July 23, 2014, 02:11:18 PM »
K thanks Ryan
No straps yet I need to order  how much shorter then overall shock extension should I order straps?
« Reply #194 on: July 23, 2014, 02:12:06 PM »
K thanks Ryan
I think 2" maybe??
